Can the ATU settings be saved in transmit or global profiles
Michael Reid
Michael Reid Member ✭✭
edited March 2017 in SmartSDR for Windows
Can the ATU settings be saved in either a Transmit or Global profile?
Flex6500 run barefoot or with an amplifier.  Transmit profile "SSB" with ATU Tune and Mem on for barefoot, and transmit profile "AmpSSB" with ATU set to bypass and Tune off and Mem off when using the amplifier.  Also each band has global profiles as, for example:  Global "20SSB" using transmit profile "SSB" and separate global "20AmpSSB" using transmit profile "AmpSSB".
The problem is that switching between the global profiles does not preserve the desired ATU setting.
Thanks, in advance, for any advice...Mike, K6DRY
  • Tim - W4TME
    edited March 2017
    No, the ATU On/Bypass state is not saved as part of any profile. You should write u p an Idea post on how would envision this working so others can comment on it.
