Will Smart SDR Beta 1.10.8 work with a Hygain DU-1 Ham IV rotor
Bill / VA3QB
Will Smart SDR Beta 1.10.8 work with a Hygain DU-1 Ham IV rotor using a USB to serial cable? I presently have it working with HRD.
Also how do you make the rotor turn on the Maestro ?
Bill
VA3QB
Bill
VA3QB
Bill, I believe from what Tim has said, it will only provide band data...DCU-1 doesn't know from band data. Right? Hows the SDR radio know where your lat/long and whoever you happen to be talking to's lat/long is to compute great circle bearing.
I don't believe you can as Maestro is a one program Windows tablet so it has no clue what your and your contact's lat/long is. HRD knows only because you told it and, by virtue of using HRDLog and entering the Q's call it knows his as well so therefor HRDLog CAN perform the great circle bearing calculation.
Another thing that is important for you to know is the DCU-1 is a fairly dumb rotor. It does not and cannot tell you where it is pointing. The only thing it does is follow your single command to turn to this bearing (0-359). In other words in the, and I use the term 'set' very loosely, cmd set there is only 'turn it to" followed by a number.
But the main thing is the radio knows not where you are or who you may or may not be talking to.0 -
Hi Bill
No, as the HyGain wants beam direction information and that is not present in SSDR. You want to use something like HRD, N1MM, PSTRotatorAZ and a few others to turn your rotator.
There are no plans to be able to drive your Beam from the Maestro to the best of my knowledge.
Most, if not all, the USB work provided by Flex has to do with Band Data management.
I hope that helps ... many 73
Mike va3mw0
- 244 Community Topics
- 481 The Flea Market
- 7.1K Software
- 331 SmartSDR for Mac
- 243 SmartSDR for iOS
- 222 SmartSDR CAT
- 162 DAX
- 348 SmartSDR API
- 8.5K Radios and Accessories
- 745 Maestro
- 41 FlexControl
- 722 Genius Products
- 250 Tuner Genius XL
- 84 Antenna Genius
- 225 Shack Infrastructure
- 150 Networking
- 120 Contesting
- 114 Amateur Radio Interests
- 805 Third-Party Software
