New Router Here Linksys WRT3200ACM
Philip KA4KOE
This is an involved process for a bricks n' mortar double E. I've performed a lot of research and it seems that the recommended wireless router is one that is "gaming" class. I'm still learning how to set up a Linksys WRT3200ACM which is touted by lots of different folks as the "bee's knees". I also upgraded my Comcast router to dual band. So the network configuration is this....
1. Downstairs cable modem/router from Comcast is set to 2.4 GHz, lets say Net 1.
2. Upstairs Linksys wireless router set to repeater mode, linked to Net 1 via 2.4 GHz. I don't think I can link to the downstairs cable modem/router via a different channel to avoid traffic packets from others in this household.
3. Upstairs wireless router hardwired to Flex 6300 via LAN cabling as is my shack computer. Wireless up here is set to 5 GHz and called Net 2. Local use of Maestro via Net 2 is fine as long as I am hardwired. I plan to have no other traffic to the Maestro when I am using it via it's dedicated 5 GHz channel. Probably should log off the main shack computer so no "I'm alive" packets get sent back and forth.
4. I intend to set static IPs for all upstairs devices; ie Linksys WRT3200ACM, my computer, and the Maestro, either hardwired or via WIFI.
5. Roll back SmartSDR to 1.8.**** prior to 1.9.****.
Anyone have any recent experience with flashing the WRT3200ACM with DD-WRT? The router is advertised as DD-WRT upgradable.
I'll keep all posted. This router upgrade was prompted by the problems previously experienced by myself and others here.
Fleep
KA4KOE
Fleep
KA4KOE
Hi Fleep,
I don't know where you live and how close neighbors are but 2.4g has been a problem in my area. My home is 600 feet from all other neighbors but still the 2.4g band is a mess with everyone's cordless phones and other junk.
I found in my area targeting the 5g band increased my data rates substantially. I also have kind of overloaded my network intentionally so I have strong sources and these tend to handle my neighbor collisions better.
Just my 2c. As I sit right now I can operate my laptop from all corners of my yard on WiFi and have pretty good results.0 -
I tried one for about 12 hours and took it back. It would not stream to the Maestro cleanly even with DD-WRT. I ended up using nothing but TP-LINK Archer C5's or C7's.
I'm finding the new ones have way too many buffering issues. More buffer space is not the solution here. BTW, what I am finding is that as I moving everything to 5GHZ (802.11A), I am now wiping out my Panasonic DECT 6.0 phones.
Mike va3mw0 -
Just because the router is listed as a "gaming router" doesn't mean it will work with the Maestro. I paid over $250 for my gaming router (Asus) and it won't work with the Maestro. I had to go back to my old Netgear to be able to use the Maestro. I was also interested in the WRT3200 but someone on here (I think it was on the community) said they had problems with this router and the Maestro. I hope it works for you.
Funny same here Mike but my reaction was to get rid of the DECT 6.0 phones. I value solid network above all. My router is the Linksys WRT1900ac working fantastic so far. It replaced an ASUS RT66 I bought this past summer, the ASUS took an early dump on me, very disappointing.0
At the remote base (aka cottage), I had to trash all the Panasonic phones. Here at the house, I am going to have to do the same thing and ditch the DECT 6 phones.1
Agreed.
BTW Mike and everyone else.
I found a freebie version of software that is REALLY useful in finding a "clear" Wi-Fi
channel so you can "hard set" your home router to a channel not colliding with the neighbors.
I was having some collision issues and determined my neighbors went with the factory settings as I had. Now the xyl and I can sit together running separate laptops and FB to our hearts content, hi!
By changing channels my wi-fi is working great.
This software will also work on 5ghz if your laptop does like on 2.4 ghz.
The freebie version tells you network names, channels, secure status and graphed signal strength.
Works in Win7 and Win10 aok...
https://www.acrylicwifi.com/en/wlan-software/wlan-scanner-acrylic-wifi-free/download-wifi-scanner-wi...0 -
HI Clay, Acrylic is great. Spend some time analyzing it. I use it all the time. The problem is not RF interference like hams are used to. It is issues with the data flow through the AP and how it is managed. It is not always so simple and there is no standard between vendors. It does make it painful.0
Excellent. So this is nothing new, just to me.
I am so happy I stumbled on it, thought I would share my new find with our flex friends.
Me too.
Its working great after setting priorities for all associated devices. 0 out of 100000 packets.
Philip - I've been having WiFi issues with my Maestro and a DLink Router. This weekend I plan to swap it out for an ASUS RT-3200. Can you elaborate what you did to set the priorities on this Router? TIA KF4HR
Some times if a problem seems intermittent of losing contact with the router, and you seem to have it fixed, but it turns up again, check to see if there might be some RFI getting into the router. I have a netgear that is exquistely sensitive to 40 meter transmissions, and it reboots. when I transmit on some frequencies around 7 MHz. The cure was a good quality Ethernet cable, and I wrapped the Radio end of the cable several turns around a 2.5 inch balun type toroid.
Just FYI for anyone having weird router problems.0 -
It's part of the web interface for the Linksys under their moniker "Smart Wifi". Also, the stream to the Maestro is a LOT better than performance using SmartSDR on a remote laptop. Weird. So, its a lot better but still some skips and jumps.
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
