WSJT 10 Audio help needed
John-K3MA
First time trying to get WSJT 10 up and working with a new 2M EME station. Using a Flex 6700. I get the following setup message and nothing shows on the WSJT screens. I am using DAX RX 1 and it is enabled in SmartSDR and the DAX panel shows audio.
Also, any other help to get the setup and setting correct would be appreciated.
Here is the screen info:
******************************************************************WSJT Version 10.0 r6088 , by K1JT
Revision date....: 2015-11-13 10:08:21 -0500 (Fri, 13 Nov 2015)
Run date.........: Wed Dec 7 19:51:17 2016 UTC
Audio Input Output Device Name
Device Channels Channels
0 2 0 Microsoft Sound Mapper - Input
1 2 0 Microphone (Sound Blaster ZxR)
2 2 0 DAX IQ RX 1 (FlexRadio Systems
3 2 0 DAX IQ RX 3 (FlexRadio Systems
4 2 0 DAX IQ RX 4 (FlexRadio Systems
5 2 0 DAX RESERVED AUDIO TX (FlexRadi
6 2 0 DAX Audio RX 6 (FlexRadio Syste
7 2 0 Digital Audio (S/PDIF) (Sound B
8 2 0 DAX Audio RX 8 (FlexRadio Syste
9 2 0 DAX Audio RX 4 (FlexRadio Syste
10 2 0 What U Hear (Sound Blaster ZxR)
11 2 0 DAX IQ RX 2 (FlexRadio Systems
12 2 0 DAX MIC Audio (FlexRadio System
13 2 0 DAX Audio RX 2 (FlexRadio Syste
14 2 0 DAX Audio RX 7 (FlexRadio Syste
15 2 0 DAX Audio RX 3 (FlexRadio Syste
16 2 0 DAX Audio RX 1 (FlexRadio Syste
17 2 0 Aux (Sound Blaster ZxR DBpro)
18 2 0 DAX Audio RX 5 (FlexRadio Syste
19 0 2 Microsoft Sound Mapper - Output
20 0 2 DAX RESERVED AUDIO RX 1 (FlexRa
21 0 2 DAX RESERVED IQ RX 3 (FlexRadio
22 0 2 2 - SAMSUNG (AMD High Definitio
23 0 2 DAX RESERVED AUDIO RX 2 (FlexRa
24 0 2 DAX Audio TX (FlexRadio Systems
25 0 2 DAX RESERVED MIC AUDIO (FlexRad
26 0 2 Speakers (Sound Blaster ZxR)
27 0 2 DAX RESERVED AUDIO RX 7 (FlexRa
28 0 2 DAX RESERVED IQ RX 1 (FlexRadio
29 0 2 DAX RESERVED AUDIO RX 4 (FlexRa
30 0 2 DAX RESERVED AUDIO RX 5 (FlexRa
31 0 2 DAX RESERVED IQ RX 4 (FlexRadio
32 0 2 Digital Audio (S/PDIF) (Sound B
33 0 2 DAX RESERVED AUDIO RX 3 (FlexRa
34 0 2 DAX RESERVED IQ RX 2 (FlexRadio
35 0 2 DAX RESERVED AUDIO RX 8 (FlexRa
36 0 2 DAX RESERVED AUDIO RX 6 (FlexRa
37 0 2 3 - SAMSUNG (AMD High Definitio
38 0 2 1 - SAMSUNG (AMD High Definitio
User requested devices: Input = 16 Output = 5
Default devices: Input = 0 Output = 19
Will open devices: Input = 16 Output = 5
Error opening output audio stream.
Errortext: Invalid number of channels
Number: -9998
Error 2 in JTaudio, you will only be able to work offline.
Number: -9998
If you examine the error message, it says error in the OUTPUT stream. You have selected #5, DAX RESERVED AUDIO TX, which is not available for your use. Select #24 instead: DAX Audio TX. The key is the word "Reserved" which indicates it is used internally by Smart SDR & DAX.
Hope this works for you!
Craig, KØCF0 -
John - I can see the error TX DAX channel needs to be 24 not 5
BTW WSJT is notoriously bad at handling audio channel errors!
Good luck on EME .. am just installing my new tower and 4 x 13 ele for 144 EME - 1KW and 0.2 dB preamp
See you off the moon soon
Cheers
Simon ZL4PLM RE66BJ
TU, I should have seen that solution. Oh well I guess I was too excited to try to decode some EME signals.
John0
- 113 SmartSDR+
- 922 Genius Products
- 124 Antenna Genius
