Don't forget to save your USB Cable configs
NX6D Dave
For the early adopters of 1.10.8, don't forget to save your radio configuration after adding a USB cable. Like most other radio parameters, the USB Cable configuration information will be lost if it becomes necessary to cold-boot the radio, but the cable configuration information is saved when the profiles are exported. Take a look at the Import/Export menu for the details.
3
Thanks for the heads up Dave.
Actually, cold booting the radio will not result in the loss of your USB Cable configuration. Doing a Factory reset will. However, it is always a best practice to backup your configuration after you have it working properly.0
Right. This is what I meant by "cold boot". Terminology from my previous life leaking through.
- 636 The Flea Market
- 143 SmartSDR+
- 261 SmartSDR CAT
- 199 DAX
- 45 Aurora
- 957 Maestro
- 57 FlexControl
- 931 Genius Products
- 302 Shack Infrastructure
- 141 Amateur Radio Interests
