Don't forget to save your USB Cable configs
NX6D Dave
For the early adopters of 1.10.8, don't forget to save your radio configuration after adding a USB cable. Like most other radio parameters, the USB Cable configuration information will be lost if it becomes necessary to cold-boot the radio, but the cable configuration information is saved when the profiles are exported. Take a look at the Import/Export menu for the details.
3
Thanks for the heads up Dave.
Actually, cold booting the radio will not result in the loss of your USB Cable configuration. Doing a Factory reset will. However, it is always a best practice to backup your configuration after you have it working properly.0
Right. This is what I meant by "cold boot". Terminology from my previous life leaking through.
- 323 Community Topics
- 577 The Flea Market
- 7.7K Software
- 6.2K SmartSDR for Windows
- 386 SmartSDR for Mac
- 253 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 365 SmartSDR API
- 9K Radios and Accessories
- 125 FLEX-8000 Signature Series
- 891 Maestro
- 50 FlexControl
- 848 Genius Products
- 437 Power Genius XL Amplifier
- 298 Tuner Genius XL
- 113 Antenna Genius
- 269 Shack Infrastructure
- 190 Networking
- 134 Contesting
- 701 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 924 Third-Party Software
