Maestro Main Tuning Knob Imbalance
Philip KA4KOE
My Maestro tuning knob seems to be slightly imbalanced. When the finger hole is in approximately the 3 o'clock position, the knob will move two steps counterclockwise. This seems to indicate a slightly heavier point opposite the finger hole. Oddly, the knob does not move by itself when the finger hole is at approximately the 9 o'clock position.
2
I have the same issue, although I haven't taken the time to determine what knob position the issue occurs. 73 Chris AK4SK0
Correction...sometimes it moves 3 clicks.
I have noticed the same problem.
A knob with two finger holes on opposite sides would solve the problem providing balance in every position, but it requires a manufacturing change.
In some older radios it was a piece of felt between front panel and turning knob increasing friction but in the same time it reduced free spinning of the knob.
If the knob is hollow on inside, one could possibly glue a piece of solder wire inside the knob near the dimple and restore the balance this way.
I recall this method used in old Collins turning knobs for increasing the spinning effect.
Tom,
SP7WT
If you have this issue with your Maestro, please open a HelpDesk support ticket.
Philip - I have converted this post to a HelpDesk ticket so you do not need to create one.0 -
We're good. Thanks.
Today I have implemented my own idea. Now the turning knob remains stable in any position.
Tom, SP7WT
? :-)0
I placed a small felt cloth patch under the edge of the tuning knob to provide some slight drag. Now I do not shift frequency when I let go of the knob. You do not notice the black felt on the Maestro.1
I have a similar issue. My Maestro main knob has a slight "tight" spot, it doesn't really turn smoothly. It isn't extreme, but noticeable. After the wait for the Maestro I was so happy with it overall, that I didn't report the issue to Flex.. They are small company and it is not like we blessed with an abundance of Ham Radio manufacturing. I kind of hate to bug them with what amounts to a "tactile cosmetic issue".
Keith - AC9S
I agree... in true ham sprit I fixed the problem myself with a small patch of black felt slipped under the edge of the knob. The drag is just right and adjustable. I will bother Flex when I have a real problem.0
- 352 Community Topics
- 617 The Flea Market
- 8K Software
- 3 SmartSDR+
- 6.3K SmartSDR for Windows
- 413 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 187 DAX
- 375 SmartSDR API
- 9.2K Radios and Accessories
- 23 Aurora
- 217 FLEX-8000 Signature Series
- 923 Maestro
- 897 Genius Products
- 325 Tuner Genius XL
- 116 Antenna Genius
- 285 Shack Infrastructure
- 200 Networking
- 138 Contesting
- 758 Peripherals & Station Integration
- 978 Third-Party Software
