Using TX1/2/3 with sequencer functionality
Tim Blank
I would like to use the TX1/TX2/TX3 outputs in lieu of a sequencer to control a vhf preamp. I see many old posts (3 years ago) that seem to talk about possible new future SmartSDR features but I see further mention suggesting anything was done. Given the lack of a 30db preamp in the 6500 it would seem to me that serious 6m users with a 6500 would need a preamp to be usable for EME and weak signal work (as proved with performance comparison with W0VB who has a 6700). Was there ever any sequencer functionality implemented in SmartSDR? Is anyone using these outputs for the application I describe?
Regards, Tim
Regards, Tim
If there ever was sequencer functionality implemented I would never use it. I would never use anything but an external quality sequencer to protect my expensive mast mounted preamps and relays for EME or bands through 10 GHz. In my case I need 3 and sometimes 4 separate timed events to happen, where you only may need one or 2. W6PQLs four Event Sequence has worked well for me and his Amplifier Control Board which can also be used to switch an LNA. Let the radios keyline start the sequence, then let a proven circuit design do the rest. Many options out there to choose from. Just my nickel input.
http://www.w6pql.com/relay_sequencer.htm
http://www.w6pql.com/amplifier_control_board.htm
2
- 378 Community Topics
- 118 SmartSDR+
- 192 DAX
- 38 Aurora
- 947 Maestro
- 924 Genius Products
