2015 ARRL 160 Meter Contest Results
Ken - NM9P
Member ✭✭✭
Well, there was a certificate in the mail today. In spite of what I though was a dismal effort in last year's ARRL 160 Contest, I apparently did well enough to score first place in Indiana in the Single Op, Low Power, Unlimited category! I almost forgot about it, which is easy to do when it takes 11 months before the certificate arrives.
3
Of course, there were only two Indiana stations in this category... but I was 11th out of 18 in the Central Division. Nothing to brag about!0
Hey Ken,
I don't contest much, but I do like 160m. I have a small lot and only have an Inverted-L for this band. I use it for XMT and RCV. A bit noisy, but it works ok.
Can you tell me what your using for antennas on this band?
Norm - W7CK
Our club's field day results were similar. #1 (of 1) in Category=2AB and Power Mult=5 for VA and Roanoke. It just means we've scared the competition away. This year I sponsored the CQ WW RTTY SOAB QRP World plaque. It looks like it is going to go to RU4SS with an amazing score. I really enjoy some of these contests even as a casual participant.
That certificate is going to look real nice on the wall Ken.
Kev K4VD0 -
I use either a 160 Offcenter fed dipole at 38 ft. Or an Inverted-L (35 up and 85 over) with two radials. It works better when I can elevate the radials about ten ft. Above ground. For receive, I use either of the antennas, or a home brew tuned shielded magnetic loop about five ft. Above ground. The loop is made of 20 ft. Of RG8 with the shield split at the top, with tuning/matching network tuned with varactor diodes. The system works OK, but I have lots of hvac motor and other noise sources on 160 at the qth.0
Thanks Ken. That's encouraging. I'll keep working with my Inv-L for now and see what I can do to improve it. Noise here isn't usually very bad but the Inv-L seems to be the noisiest.
I have to admit, I hear things on the 6700 that I don't on the IC-7100.
From what I have read, using as few as two or four elevated radials (about 8-10 ft. above the ground) increases efficiency over buried radials. until you get to about 32 in-ground radials.
I have proven this on my 40 meter vertical with only 4 radials at 8-10 ft.
On the 160 inverted 'L', I can manage 2-3 temporary radials, even though they are bent to a 90 degree angle after about 65 ft. I quickly angle them up to 8-10 ft for the first 10 ft. and then support them with 1/2 inch electrical conduit shoved about a foot into the ground every 20 ft or so to keep them from clothes-lining people in my backyard. After 160 season, I roll the inverted 'L' and radials up on an electrical cord reel and store them until the next season....
When I just lay them on the ground, I don't get as good performance. I haven't been able to fully understand the radiation efficiency difference, but it seems it has to do with ground capacitance, etc.... I still need to do some more study. But I am contemplating doing the same thing with an 80 meter inverted 'L.' I think I may be able to squeeze 4 elevated radials into the yard, somewhat bent, perhaps using two of the 160 radials as part of the system this winter.
Perhaps some of the other 80/160 experts will chime in with some suggestions?0
- 379 Community Topics
- 631 The Flea Market
- 120 SmartSDR+
- 193 DAX
- 38 Aurora
- 947 Maestro
- 924 Genius Products
