SO2R audio muted when Dual CQ N1MM or DX Log on 6700
Kari Gustafsson SM0HRP
I just got DXlog working in SO2R mode but as I use mode where I can TX on slice A and listen on slice B (on another band) the slice B gets muted more or less. Same happens with N1mm in Dual CQ mode. This is problematic as you wan to do S&P on slice B while sending on slice A. The same happen when changing TX to slice B and listening on slice A.
I use Maestro and I cannot see if I can alter this anyway...? I listen on audio output (front) of 6700 as I use an external Winkeyer WKUSB for CW generation.
This is traditionally controlled from the logger in SO2R mode.
according to the documentation online for this program..AltGr-S, Ctrl-Alt-S: Listen to both radios in stereo (toggle)
http://dxlog.net/docs/index.php/Commands
here is the entire command set online including SO2R
heres more specifics
AltGr-A, Ctrl-Alt-A: Listen to the primary radio with both ears AltGr-T, Ctrl-Alt-T: Listen to the secondary radio with both ears AltGr-S, Ctrl-Alt-S: Listen to both radios in stereo (toggle) AltGr-L, Ctrl-Alt-L: Listen to the "other" radio with both ears during transmit (headphone "latch") AltGr-R, Ctrl-Alt-R: Restore automatic control (advanced scenarios will control headphones, like $RESET) AltGr-1...AltGr-8, Ctrl-Alt-1...Ctrl-Alt-8: Select one of the eight SO2R scenarios
I do not think this alters it. Same strange behavior in N1MM and as far as I know no means here to influence audio in one ear or both... In Morserunner mode of SO2R and DxLog it works as you expect. (I will send you screenshots of my set up tomorrow)0
In N1MM on a US keyboard the ~ key unmutes both slices in SO2R mode.
- 332 Community Topics
- 600 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 399 SmartSDR for Mac
- 263 SmartSDR for iOS
- 247 SmartSDR CAT
- 184 DAX
- 370 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 169 FLEX-8000 Signature Series
- 912 Maestro
- 52 FlexControl
- 879 Genius Products
- 317 Tuner Genius XL
- 116 Antenna Genius
- 279 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 730 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 949 Third-Party Software
