CW from keys F1:::F12
Felice, IZ8FFA
Cw mode, if I change band typing the new frequency in the slice window and then try to transmit using the keys from F1 to F12, then the radio doesn't go on TX.
After that if I simply hit whatever button on the control panel,e.g. RF power slider, the rig starts transmitting as usual.
Is there someone else with the same issue?
TNX
Felice, IZ8FFA
TNX
Felice, IZ8FFA
Felice , SSDR can't monopolize keyboard , for usage of F keys for CWX operation SSDR should be active window for user. BTW in any time you can use well buttons on Flexcontrol0
Good Morning Sergey and thank you for the replay.
Sorry, but before this ticket I have check this problem with a firends of local comunity and from about 20 memberes, only 3 of this have reported a problem. Now you are another one.
Felice this is not a problem but SW as designed as any others on WIN system0
- 378 Community Topics
- 117 SmartSDR+
- 37 Aurora
- 946 Maestro
- 923 Genius Products
