what is the amost current update ?
John Molenda
with out much thought I upgraded the software on my 6700 to 1.9.9 and then I visited the fexlradiosysystems web site and it states that the latest update is 1.9.13 and I do not run maestro . so is it ok to run 1.9.9 with not using maestro or should I load 1.9.13 ?
Also when will I be able to run real diversity reception using two antennas ? How long do I need to wait for the 2.0 update ? thanks John kb2huk
John, It won't hurt to load the 1.9.13. It may have a few improvements. You can run true diversity today. I do it almost every day on two different yagis on two different towers. Page 67 of the SmartSDR Software users guide. The 2.0 update will primarily give you the ability to operate your radio over the wide area network (Internet) without using a third party application like SoftEther. 73, Mack W4AX Alpha Tester0
Apparently in the software world ".13" is treated as a higher number than ".9". In the mathematical world, of course, ".9" is higher than ".13". Think of it this way: if software version, add "0s" before the number; if math, add "0s" after the number. So if software, ".9" = ".09". If math, the same ".9" = ".90". (Don't ask why, I haven't a clue.)0
The decimal point before the suffix does not have any relationship to the number 9. You have to really dumb down and realize that 13 is larger than 9. Life is hard being a ham and network nut.
Jim, K6QE
- 324 Community Topics
- 589 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 393 SmartSDR for Mac
- 260 SmartSDR for iOS
- 246 SmartSDR CAT
- 178 DAX
- 368 SmartSDR API
- 9K Radios and Accessories
- 14 Aurora
- 149 FLEX-8000 Signature Series
- 906 Maestro
- 50 FlexControl
- 865 Genius Products
- 307 Tuner Genius XL
- 114 Antenna Genius
- 273 Shack Infrastructure
- 193 Networking
- 135 Contesting
- 715 Peripherals & Station Integration
- 134 Amateur Radio Interests
- 936 Third-Party Software
