fldigi and voice meeter banana
Roger Rockwell/na4rr
I have been running voice meeter banana as a audio log for my NPOTA activations.and when I activate a county for the county hunters. Last night I thought I'd get away from the contest and work some psk31. I started fldigi and no receive. Nothing on the waterfall. I checked and re checked every setting and could find nothing. Then I closed the voice meeter program and fldigi came to life. Played with it today to verify and it happens every time. If the voice meeter program is loaded and I start fldigi ,no receive. on fldigi. If I start fldigi first then I can start voice meeter and all works fine. I tried the same using Audacity and there is no conflict. I cant see this being a huge problem and the problem is probably not with fldigi. Just thought I would pass on the information in case someone else can not figure out why fldigi is not working. 73 roger
Is that the real name for the program?0
Here is a description http://streamersquare.com/voicemeeter-banana-overview/
It works great to record both xmit and rec. As someone said in another conversation it takes a little fiddling to get set up. I use it to proof all my activations. Out of about every 100 Q's I will type in a cal as w1acb instead of w1abc. I always seem to swap the last two. Anyway it's interesting to hear what I didn't hear the first time.
roger0
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 71 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
