fldigi and voice meeter banana
Roger Rockwell/na4rr
Roger Rockwell/na4rr Member ✭✭
edited July 2019 in Third-Party Software
I have been running voice meeter banana as a audio log for my NPOTA activations.and when I activate a  county for the county hunters.  Last night I thought I'd get away from the contest and work some psk31.  I started fldigi and no receive.  Nothing on the waterfall.  I checked and re checked every setting and could find nothing.  Then I closed the voice meeter program and fldigi came to life.  Played with it today to verify and it happens every time.  If the voice meeter program is loaded and I start fldigi ,no receive. on fldigi.  If I start fldigi first then I can start voice meeter and all works fine.  I tried the same using Audacity and there is no conflict.  I cant see this being a huge problem and the problem is probably not with fldigi.  Just thought I would pass on the information in case someone else can not figure out why fldigi is not working.  73  roger
