SLR connector on the 6500?
W2NER
I have a 6500 coming (sold my 6300) and I know there is a SLR connector on the back. What are the advantages of using the SLR connector over the 8 pin on the front?
I believe a balanced line used by the XLR connector helps eliminate common mode noise.
An excerpt from Empirical Audio:One carries the uninverted signal and the other carries the inverted version of the same signal. Because the two signal wires carry inverted versions of each others signal, the receiving component only needs to sense the difference in the two signals. It will ignore any signal that is identical and common to both wires. This is a great advantage, because most noise sources will generally cause the same noise to appear on both wires (common-mode), such as 60 Hz noise from ground-loops or strong RF.
I'll second Kevin's remarks. Balanced audio is generally less susceptible to noise. For amateur use, it's probably not a big fidelity difference for communications-grade audio, so if you're happy with your current mic setup there is no reason to change. If you have a studio-style mic, it may be fun to try. I have a headset mic in the front jack for contesting/DX, and a desktop mic in the XLR for casual use. Both work great. Make sure you set up good mic profiles (EQ) for both.0
Couple of comments to add to the already valuable information shared by Kevin and George.
The connector in the back of the 6500-6700 allows for both XLR and 1/4 male jack in the same socket.
And, another advantage to using both the front and back connectors is that you can switch from one to the other from SmartSDR with a mouse click. So you can have a desk mic connected to the back for armchair rag chewing and easily switch to headset for a DX without having to unplug anything.0 -
One day when I'm a big boy I'll have a desk mic! Right now I use my RadioSport headset.0
Thanks guys0
LOL! You could do a LOT worse than a RadioSport! It took me all of about 15 seconds after putting one on at the Dayton Hamvention to decide to add it to my list of essential purchases! I have never worn a more comfortable headset.
I am saving up for one myself, which I will add to the front panel along with my Heil PR22 on the Back XLR connector.0 -
Tell you what, my wife hates the headset, why? because when she calls for me I can never hear her. I even used them one time out on the tractor as was dragging the yard for weeds! They are a really good headset. Bob and his friends over on K6UDA YouTube didn't like them so much compared to Heil's but I found the Pro7's not to be for me, YMMV.0
For me, the advantage of completely blocking outside noise is offset by the extra pressure just bellow the ears on the jaw line. I use the CM500, because I can wear them for hours without much discomfort. I am afraid that the Pro7 or Radiosport will be too tight. Perfect for a noisy environment (contest station) not as great in the home (<--- for me).0
Salvador I had the same problem I talked to Dave when I was at Visalia and he said just bend the headband to fit and showed me how and since then I have worn them 12 hours straight with no discomfort at all. 0
I can't wait to go to one of these shows and test them. I have not put either one on, ever, so I am basing my opinion on how other mechanical noise canceling headphones have felt in my head. Thanks for the tip Rory.0
- 314 Community Topics
- 574 The Flea Market
- 7.7K Software
- 6.1K SmartSDR for Windows
- 365 SmartSDR for Mac
- 251 SmartSDR for iOS
- 242 SmartSDR CAT
- 174 DAX
- 356 SmartSDR API
- 9K Radios and Accessories
- 119 FLEX-8000 Signature Series
- 855 Maestro
- 50 FlexControl
- 804 Genius Products
- 279 Tuner Genius XL
- 103 Antenna Genius
- 268 Shack Infrastructure
- 189 Networking
- 428 Remote Operation (SmartLink)
- 132 Contesting
- 695 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 920 Third-Party Software
