My Power SDR (both 2.7.2 and Darrin's T10) have stopped showing the CPU %, F'heit/Celsius toggle
Peter
My Power SDRs (both 2.7.2 and Darrin's T10) have stopped showing the CPU% (it does not even appear on the screen) and I cannot toggle F'heit/Celsius (which do appear, but do not function). Apart from those matters, the programs function without a problem, with no noticeable latency.
I am running Vista and a Flex 3000. The CPU normally operates at about 60% on a core duo PC. The problem arose recently and suddenly on boot up, with both operating normally on shut down the previous day. I have re-installed both programs and the problem persists. This is my only issue and both relate to the lower left hand corner of the screen.
Could I have unknowingly toggled the indicators off, or done something within Vista?
The CPU% still indicator within Vista's Control Panel still functions.
Thanks for your efforts Darrin. Wonderful improvement, and very much appreciated. I will install T11 shortly.
Peter,
I also have noticed the same things you have mentioned, and like you-- where wondering if is was my PC or something else on my side.
Will wait and see if other's report it also.
Regards,
Larry
Always check the HelpDesk....
https://helpdesk.flexradio.com/hc/en-us/articles/202118438-CPU-Utilization-not-being-displayed-on-Po...
Thanks Tim-----Talk about great product support!
Larry
N7ZDR
Thanks Tim, however I had seen that article in the Help Desk, and applied it without any success. I did receive the message "Successfully rebuilt performance counter setting from system backup"
I am still left with no CPU performance indicator showing, and I am still unable to toggle Centigrade/F'heit OR to display Volts. These did all work nicely, but not now.
I also note that "Space WX (in the OFF position) cannot be toggled ON (however I do not use this feature). My "Date" and "LOC Time" work just fine.
Any further suggestion?
Peter
In PowerSDR, we use a .NET class to get the CPU utilization. It is a simple piece of .NET code. If it doesn't work, then two things are happening; (a) it did not return a valid value from the performance counters (what the HD article addresses) or (b) there is something amiss in WinForms preventing a valid value from being displayed.0
Peter, I will try this fix when I get home tonight and report back.
Larry
Hi Larry,
Great! It did not work for me. I might have to install Windows 7!! I should do that anyway as Vista is no longer supported by Microsoft.
Next week I can access another PC with Vista installed, along with Power SDR & T10. If the Flex 3000 works correctly on this other PC, I am then rather sure it is a PC issue I have at present.
I hope Tim's "fix" works for you!
Cheers,
Peter0 -
FYI,
I had the 3000 running for about 3 hours last night. I never needed to perform the "fix" and all worked well. Will continue to watch this and report back.
I will add that I do shut the PC down every night and this re-boot could have corrected it.
Regards,
Larry0
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
- 456 Remote Operation (SmartLink)
