My Power SDR (both 2.7.2 and Darrin's T10) have stopped showing the CPU %, F'heit/Celsius toggle
Peter
Peter Member
My Power SDRs (both 2.7.2 and Darrin's T10) have stopped showing the CPU% (it does not even appear on the screen) and I cannot toggle F'heit/Celsius (which do appear, but do not function). Apart from those matters, the programs function without a problem, with no noticeable latency.
I am running Vista and a Flex 3000.  The CPU normally operates at about 60% on a core duo PC. The problem arose recently and suddenly on boot up, with both operating normally on shut down the previous day.  I have re-installed both programs and the problem persists.  This is my only issue and both relate to the lower left hand corner of the screen.
Could I have unknowingly toggled the indicators off, or done something within Vista?
The CPU% still indicator within Vista's Control Panel still functions.
Thanks for your efforts Darrin. Wonderful improvement, and very much appreciated.  I will install T11 shortly.
  • Larry Williamson
    Larry Williamson Member ✭✭
    edited June 2018
    Peter,
    I also have noticed the same things you have mentioned, and like you-- where wondering if is was my PC or something else on my side.
    Will wait and see if other's report it also.
    Regards,
    Larry
  • Tim - W4TME
    edited March 2017
  • Larry Williamson
    edited June 2018
    Thanks Tim-----Talk about great product support!
    Larry
    N7ZDR
  • Peter
    Peter Member
    edited March 2017
    Thanks Tim, however I had seen that article in the Help Desk, and applied it without any success. I did receive the message "Successfully rebuilt performance counter setting from system backup"
    I am still left with no CPU performance indicator showing, and I am still unable to toggle Centigrade/F'heit  OR to display Volts. These did all work nicely, but not now.
    I also note that "Space WX (in the OFF position) cannot be toggled ON (however I do not use this feature).  My "Date" and "LOC Time" work just fine.
    Any further suggestion?
    Peter
  • Tim - W4TME
    edited December 2016
    In PowerSDR, we use a .NET class to get the CPU utilization.  It is a simple piece of .NET code.  If it doesn't work, then two things are happening; (a) it did not return a valid value from the performance counters (what the HD article addresses) or (b) there is something amiss in WinForms preventing a valid value from being displayed.
  • Larry Williamson
    edited June 2018
    Peter, I will try this fix when I get home tonight and report back.
    Larry
  • Peter
    Peter Member
    edited October 2016
    Hi Larry,
    Great!  It did not work for me.  I might have to install Windows 7!!   I should do that anyway as Vista is no longer supported by Microsoft.
    Next week I can access another PC with Vista installed, along with Power SDR & T10.  If the Flex 3000 works correctly on this other PC, I am then rather sure it is a PC issue I have at present.
    I hope Tim's "fix" works for you!
    Cheers,
    Peter
  • Larry Williamson
    edited June 2018
    FYI,
    I had the 3000 running for about 3 hours last night. I never needed to perform the "fix" and all worked well. Will continue to watch this and report back.
    I will add that I do shut the PC down every night and this re-boot could have corrected it.
    Regards,
    Larry
