Lightning strike at NM9P
Yes, the ESD protection ICs designed to be sacrificial during an EMP or static discharge into the radio to protect the SCU did their job very well.0
Glad they were there! No telling how expensive the repair might have been without them. Too bad there isn't an internal test routine that displays "You fried it! Front end now unprotected!". When that happens! Ha ha!1
I had similar issue they thought caused by. Lightening and it toook out the antenna relays. About the same price to repair and very quick Mike0
Wish the good practice of sacrificial-protector ESD Diodes was more widely used. Wrote off much gear back when back-feed on the power line from a neighbor's tree 75 ft from the service easement being blown up by lightening.
Antenna protection didn't matter in this case, as one side of the 240v service and the ground were super-energized. Looked like an arc-welder had been fired off inside the cases when we opened the gear up.
Steve K9ZW
As Ken wrote above, if the symptom of diode damage is an elevated noise floor, is it possible (or could it be) for the radio to tell the owner what has happened? Ken was attentive, but also considered other external possibilities for the elevated noise level.
I'd hate to think I'm listening through damaged diodes and not knowing it.
Worked Ulrich, VP6AH, on Pitcairn today. I was 5x7 with him, while he was 4x4 with me. Don't want to be an Alligator, all mouth and no ears.
Gary W4EEY
Perhaps the 7300 was performing very well (tongue-in-cheek)
Gary - there is no way for the radio to inform you that the ESD diode is blown other than having an elevated noise floor that what is usually normal for your QTH.
You could put a signal of known strength into the radio and read the output and if they differ significantly, then I would send the radio in for service.0 -
Thanks Tim!
Gary W4EEY
I have an Elecraft XG2 that I use for providing a (mostly) known signal level into the radio.0
Why mostly Tim?
Doug g4ovr.
Because, for the price, it was not designed to be a high precision signal generator. You will have to use it to determine the actual signal level so you have a known quality before you use it to determine the amount of attention.0
- 342 Community Topics
- 611 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 406 SmartSDR for Mac
- 265 SmartSDR for iOS
- 249 SmartSDR CAT
- 186 DAX
- 373 SmartSDR API
- 9.2K Radios and Accessories
- 20 Aurora
- 197 FLEX-8000 Signature Series
- 919 Maestro
- 889 Genius Products
- 322 Tuner Genius XL
- 116 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 137 Contesting
- 746 Peripherals & Station Integration
- 138 Amateur Radio Interests
- 965 Third-Party Software
