SMART SDR v1.0.7 TX Level not working correctly
Cal N3CAL
Just updated my iPAD Mini 4 to SSDR v1.0.7 and noticed my TX Level is maxed out all the time when iPAD is selected. When PTT is depressed the level goes full right into the yellow and red at the 0 level. Making any adjustments to mic gain does not matter it's always displaying max right????? Any ideas?
I've also noticed the compression level seems to be working but it's almost 3/4 full left.
Cal/N3CAL
Cal/N3CAL
Hi Cal,
SSDR for iOS 1.0.7 also does the same here. Using an iPad Pro, during TX, the level meter is pinned full-scale when the iPad input is selected. A workaround I have discovered is to enable the level meter during receive (on the Flex Settings / Phone menu). Then the level meter seems to work correctly while transmitting. Of course, it flickers incessantly during receive if you are using the iPad's built-in speakers. (A tangential question: Is there a way to control the mic noise cancellation such as is used in Skype?)
The compression levels could be excessive because you might be over-driving the mic level. Hard to tell without a functioning meter.
Despite a few minor bugs,SSDR for iOS is a very impressive app.
73, Bob, N7ZO0 -
Hi Cal,
thanks for reporting this. There is a setting under "Flex ... settings" -> Phone -> Level Meter during Receive. If you switch it on, the level meter will work.
This is obviously a bug I will fix with the next version but switching on this setting will at least work as a workaround (even though it's only working on TX not on RX).
@Bob: you wrote "few minor bugs", are there additional bugs I am not aware of ? My bug list currently only has this new "Level Meter" bug listed.
vy 73,
Marcus
There ability to store a negative repeater off set still does not work. I have to set up a "split" with one receive and one for transmit for it to work. The memory data file always returns a 0 value after entering .6 or .600 when you come back to it later. Watts K4QJZ0
Ah, ok, thanks, but it isn't implemented the way that you have/need to enter a negative value. There is a Reverse switch (which was missing and which is now available) just like the "REV" button in SmartSDR for Windows.
Can you try this please and let me know.
vy 73,
Marcus
Thanks everyone for the reply! I've got the level meter turned on during receive now and it's working ok. 73
Cal/N3CAL
Hi Marcus,
The only other current bug I was aware of is the negative repeater offset issue, but you have addressed that.
73, Bob, N7ZO
Thanks Bob, this is good to know. I am of course pretty sure that there might be some additional bugs as this is software and we are human but I hope at least there is no major bug but even though I am interested to know any bug regardless of small or big so I can put them on my ToDo list.
But for now, I am happy that there isn't any (additional) and so I can concentrate on adding new features like logging or Behringer DJ controller support.
Thanks again guys,
vy 73,
Marcus
Marcus, I just noticed that if the level meter is enabled for receive, when I mute the speaker using the icon on the top menu, it also stops the level meter and leaves it at whatever level it was when the mute icon was pressed.0
Thanks Bob, it is probably related but good to know so I can check for this as well after fixing this.
vy 73,
Marcus, DL8MRE
- 112 SmartSDR+
- 944 Maestro
