Maestro sound
Chris DL5NAM
Member ✭✭✭
Bug or feature?
I operate at Shack, running SSDR on Win PC, active speaker connected direct to TRX. Parallel i install new version of SSDR-IOS on Pad. Installation was easy as ever and successful.
I exit SSDR on PC and no longer any sound from speaker. That's normal.
Now i want try Ipad (via WiFi, 1m away from router). I start APP, app coming up like normal
But what happend now!?!?
Sound came from Ipad . If i mute the Ipad speaker, sound came now from my active speakers now, and if i open left menu Audio with Lineout Volume i can change volume of active speakers at Flex6!! If i switch off Mute at Ipad, sound from Ipad and speakers are quiet
I close App and reopen it. Same result.
Now again. Is it a bug or a feature ? :-)
Have made a small video can send on request
73 Chris
73 Chris
Hi Chris, that's indeed a feature. The button at the top actually switches between local and remote audio similar to the remote button in Smartsdr Win.
And of course, if you change the line out volume slider, the speaker volume will be changed as the speaker is connected to line out.
vy 73,
Marcus
Part 2: if i open right Menu and click Mute button active speaker are quiet, if not on Mute i can change volume of active speakers with slider. ??0
Now we have 3 Mute buttons ? OK, never stop learning :-)0
Yes, that's right and the same in SmartSDR Win.
Keep in mind, the right menu is for the currently selected (active) slice. Here, you can mute a slice and control the volume of a slice not the general volume.
vy 73,
Marcus0
- 379 Community Topics
- 631 The Flea Market
- 122 SmartSDR+
- 193 DAX
- 39 Aurora
- 263 FLEX-8000 Signature Series
- 947 Maestro
- 924 Genius Products
