DStar problem with SmartSDR 1.7.30
Gary L. Robinson
I installed the latest SmartSDR, v1.7.30, to my Flex 6300 and all went well and no problems until I tried DStar. I uninstalled all Flex software and versions before I installed SmartSDR 1.7.30.
All seems to work well in FM, SSB, CW, and digi modes. But I tested DStar using my ThumbDV drive and my Elecraft 2mtr transverter and saw some strange things happen.
At first it seemed to work well and I was talking and getting a good report from a buddy of mine on the local DStar repeater. Then, after a short period of time, perhaps 1-3 minutes, the DStar waveform companion app went totally grayed out for a second and I get a notification saying it (the app) just connected the radio. Apparently it disconnected and reconnected. And then it started cycling about every 15-16 seconds connecting.
Actually I don't see any notifications saying it is logging out so I am assuming that since the app goes grayed out and then un-grays a second later after the connect notification.
And it just keeps cycling whether I am transmitting OR not.
Using Windows 10 on 2.6ghz Quad core AMD with 8gb RAM.
As far as I can tell all other modes doing OK.
I did uninstall completely DStar and rebooted the Flex and Windows - then reinstalled DStar but same thing still happens when I start the DStar app. Just continually connects (and I ASSUME) disconnects every 15-16 seconds.
Has anyone else seen anything like this with DStar in SmartSDR 1.7.30 ??
---Gary WB8ROL
---Gary WB8ROL
I HAVE A 6500 doing the same thing. I am using the 6500 and DV3000 on DSTAR HF. The SMARTSDR DSTAR Waveform program seems to reboot about every 15 seconds or sow. Then the little window comes up and says Client Connected from IP 192.168.1.132. I am also running DDUtil 3.2.3
I am glad I am not the only one seeing this hihi I don't do all that much DStar so it's not a "critical" thing but you never know if it's something you did or 'what' until someone else reports the same thing. I am not using DDUtil here though I use a homebrew app of my own. Naturally, I stopped using my app to see IF it was causing the problem but that did not help. I did NOT try FreeDV to see if it's a waveform 'thing' or just a DStar waveform 'thing'. I will try that later today.0
I'm testing it now, had not opened DStar since I did the upgrade... FYI, I always remove both FreeDV and DSTAR waveforms and reinstall them after an upgrade. So far, been running about 20 minutes so far but no DSTAR issues or the SmartSDR DSTAR Waveform program running issues either.
FLEX-6500
Windows 10
SmartSDR 1.7.30
SmartSDR DSTAR Waveform 1.0.7.9
David
KK4QOE
FYI.. ran the application with slice A up and running DSTAR for over 30 minutes without issue.. did you guys try uninstalling and reinstalling the DSTAR waveform??
David0 -
Gary - how frequently has this happened?0
Sorry for late reply but was gone all day hihi
It seems to happen every time I use DStar. When I first start DStar it does not happen immediately but after a few transmissions (or maybe it's just a time interval - not sure) it then starts cycling as noted above. When it does, the folks I talk to say I become very unintelligible. I can close and restart the companion app and IF I am real quick I can get a clean intelligible signal to them before it starts cycling again. Long enough to say 73 my bug is still messing things up.
Anyhow the problem seems reliable. I start up SmartSDR, go to DStar (using a profile) and do some transmissions - sometimes for a mute or so and then it starts cycling. After that, I can remover for 15 seconds by closing and restarting the companion app for the wave form. Then it starts in again. If I leave it on it just goes on cycling forever.
Anyhow, I have uninstalled ALL wave forms and then reinstall just DStar and that does not help. I have tried same thing and rebooting both the 6300 and Windows 10 and still - back it comes when I start things up and go to DStar.
Which makes me wonder - after I start the companion app and set it for freq etc. Can I turn off the Companion app and still be OK on DStar as long as I don't need to do any changes? I'll try that and report back.
---Gary WB8ROL0 -
Yep, I can set my DStar to ECHO mode and turn off the companion app and I can transmit all day and hear my clean audio come back to me. So it definitely seems like the companion app is connecting and disconnecting ever 15 seconds while IT is running and that is affecting my DStar signal or datastream or whatever. But if I turn it off all is OK. Except I can't use the app hihi
---Gary WB8ROL0 -
I have entered this problem report with all of your comments into our bug tracker for additional investigation. This is defect #3608. Thank you for the defect report.
Has there been any update on this issue. I just attempted to use DSTAR for the first time over the weekend and I'm seeing this on the latest Smart SDR (v1.9.13), makes the function pretty much unusable :-(
1.9.13 does work DSTAR HF. But every random time, about 30sec- 2min get a reconnect warning. Kent, KQ4KK, DSTAR HF NET NCS.0
I have updated defect report #3608 with this information.0
- 342 Community Topics
- 611 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 406 SmartSDR for Mac
- 265 SmartSDR for iOS
- 249 SmartSDR CAT
- 186 DAX
- 373 SmartSDR API
- 9.2K Radios and Accessories
- 20 Aurora
- 197 FLEX-8000 Signature Series
- 919 Maestro
- 889 Genius Products
- 322 Tuner Genius XL
- 116 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 137 Contesting
- 746 Peripherals & Station Integration
- 138 Amateur Radio Interests
- 967 Third-Party Software
