Problem Reporting question.
Harold Rosee
I have a quick question on problem reporting. I found an issue and searched the forums to see if it had been discussed before. I found that it had. I spent quite a bit of time to see if I could recreate the problem and was able to do it at will. I took notes and screen shots. My question is do I report it as a new issue or should I some how add it to the existing issue assuming I can find it? The thread was closed so I can't add the info there.
Here is the link to the post I am referring to:
https://community.flexradio.com/flexradio/topics/anyone-else-notice-their-6xxx-not-changing-bands?to...
I can recreate this at will and also get a good screen dump of error that may help. Just don't know the best way to pass the info on.
Harold
Harold
Notice the "Official Reply" in that thread. Once the problem has been "logged by FRS Engineering", that means it is duly noted and on the list of bugs to be fixed.0
I had a similar band changing problem last night with Maestro, using v1.9.9.20 because it would not update to v1.9.13. I could change to any band except 12M (using Maestro band buttons), but I could go to the 12M band by typing in the frequency, just not by using the band frequency button. However, upgrade to v1.9.13 today, appears to have resolved that issue.
BTW, Give this a try and see if you can do it.
1. Start SmartSDR.
2. Note the band it comes up on. In this example mine is on 20 meters.
3. Select a Memory on a different band. I selected on on 40 meters from a memory.
4. Using the Band buttons select back to the original band of 20 meters. You will notice the volume goes real loud.
5. Using the band buttons and go back to 40 meters. Your slice will go away!! Volume goes back down. I think it's still on 20 meters but didn't check.
Do this enough times in one session and you get a screen dump of errors when you try and stop the program. It's something to do with switching between memories and Bands. I can do this over and over. I am new to SmartSDR so 1.9.9 was the first release I used and it was happening there. I waited for the next release, now on 1.9.13, and it's still happening.
Let me know if you can recreate this. Hope this makes sense.
Harold
I understand that but I have information to pass on that may be helpful. Thus my question.
If you have any info, just open a helpdesk ticket and tell them in the notes that you understand this may be a duplicate but here may be some usefull info. Flex can then figure out how to handle it and you may have contributed additional info Cheers!1
The implication is that they are able to reproduce the problem and they have the ball. Usually, the only time they will ask for additional information is if they are unable to reproduce the problem. But hey, post everything ya got. Cheers,0
Were your memories created with previous versions? Try creating a couple of memories with 1.9.13 in the same bands to see if the problem persists. I think that adding extra information is helpful and if more people suffer the bug it might rise up in the priority list.0
Harold,
Bob is correct. If we have entered it into our bug tracker, it means there is a high probability that the issue is a defect and requires additional investigation by our engineering team.
We always welcome additional information. More is always better than less.
There is an easy "rule of thumb" to follow. If you want to communicate something officially to FelxRadio systems about an issue that may or may not have been previously reported, open a HelPDesk support ticket. (http://helpdesk.flexradio.com). While I do my best to read every post on the community, there are times where this isn't possible, so entering a HD ticket will get to the support team and they will direct it to the appropriate person to update the defect report.
The defect in question, #4064 is slated to be addressed in the next general release of SmartSDR. I say "slated", because it has been scheduled, but work has not started on it.
Tim, Thanks for the reply. I did try and open a ticket last night. It appeared to go through and the last screen told me to watch my EMAIL so I could validate it or something similar. I never received anything so not sure what happened. I basically pasted the info from here on how to recreate the issue. If you find it useful feel free to copy it into a ticket. For some reason I don't seem to be able to open one.
Harold
Check SPAM folder. Helpdesk tickets from Tim go to SPAM in my gmail account.0
Not there. Already checked but thanks for the suggestion.
Harold, I do not see any recent HelpDesk support submissions under your account.0
I'll try again tonight. I signed into the forums here with my facebook account but when I made a couple of purchases yesterday I used my email and password. I may have things messed up on my end. No telling but I'll try again.
Tim,
I got it entered. Somehow I have a couple different accounts set up. I use hotmail and it lets you set up an alias. When I changed my call from wa5zzt to w5zzt I set up an alias email for the new call. My purchases are under the new email and my ID here and on the support site are under my old email. A little confusing but I got it figured out now.
Harold
- 332 Community Topics
- 599 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 398 SmartSDR for Mac
- 262 SmartSDR for iOS
- 247 SmartSDR CAT
- 181 DAX
- 370 SmartSDR API
- 9.1K Radios and Accessories
- 16 Aurora
- 912 Maestro
- 52 FlexControl
- 873 Genius Products
- 312 Tuner Genius XL
- 115 Antenna Genius
- 278 Shack Infrastructure
- 196 Networking
- 135 Contesting
- 727 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 948 Third-Party Software
