Global Profile Save includes Mic and/or TX Profile Save
Rich McCabe
Member ✭✭✭
This is a slight annoyance with me. When I save a Global Profile I dont want it to save a Transmit and Mic Profile with my Global profile name if I had made a slight tweak to either mic or transmit settings.
As an example I occasionally update a Global profile with some new layout settings. During that session I may have adjusted the Mic gain slightly. If I re save the global profile again as "160m -4K" to update my global settings I will end up with a mic profile named 160-4K if I had made any changes to any mic function. All I want was to update my global profile which is all I wanted. If I wanted a new mic profile added with a name that is probably inappropriate I would have saved that as well.
So I end up going back and deleting random profiles from Mic and TX.
Maybe don't update anything, just make changes and leave it, it will be remembered next time you start up.
It wont for me because I use my profiles as a band switch. Have my Panafalls and everything setup per band not to mention custom ones for things like 20m-PSK
- 378 Community Topics
- 116 SmartSDR+
- 37 Aurora
- 923 Genius Products
