Turn on 6300 via maestro
Jim Brinza
Is there a way I am missing to turn my 6300 on and off via the Maestro? Thanks Jim
No is the short answer. That's what I do on my remote base and the radio remains in hotstandby. If I want it off, I can control it via the RCA connector on the back.
If you turn it off (right off), then the Maestro has no way of seeing the radio on the network. The same is true for SmartSDR.
Mike va3mw
Jim, I use an IP power **** to turn on and off a 12v relay that shorts the remote RCA. I have some friends that use a Wimo to do the same. https://www.amazon.com/Managed-Designed-Manufactured-Synaccess-Networks/dp/B0039OZKPE https://www.amazon.com/s/ref=nb_sb_noss_2/153-3739096-2749960?url=search-alias%3Delectronics&fie...
Jeff N3VE
- 378 Community Topics
- 116 SmartSDR+
- 37 Aurora
- 923 Genius Products
