Turn on 6300 via maestro
Jim Brinza
Is there a way I am missing to turn my 6300 on and off via the Maestro? Thanks Jim
No is the short answer. That's what I do on my remote base and the radio remains in hotstandby. If I want it off, I can control it via the RCA connector on the back.
If you turn it off (right off), then the Maestro has no way of seeing the radio on the network. The same is true for SmartSDR.
Mike va3mw
Jim, I use an IP power **** to turn on and off a 12v relay that shorts the remote RCA. I have some friends that use a Wimo to do the same. https://www.amazon.com/Managed-Designed-Manufactured-Synaccess-Networks/dp/B0039OZKPE https://www.amazon.com/s/ref=nb_sb_noss_2/153-3739096-2749960?url=search-alias%3Delectronics&fie...
Jeff N3VE
- 383 Community Topics
- 640 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 262 SmartSDR CAT
- 201 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
