on 80 M band im receiving shortwave signal in all band and the noies livel is over s9 + ?
On 80M band im receiving shortwave signal in all band and the noies livel is over s9 + ?
and also if i change band to 40 meter or 20M Or 18M the radio will still receive the shortwave signal until i tune it then will despir and back to normal ...!!
Hello Osama.... we talked on 40 a few days ago ... I had read yesterday where someone had said that they had lots of BC stations interfering .... and the explanation was that if the panadapter is wider than the band where one end or the other is outside of the band - then the receiver is opened up to the WIDE mode... this guy was on 160 and had the bottom of the panadapter set to 1.790 ... if he moved the edge of the pan up slightly all was fine ... note this is the panadapter and not the slice... is it possible this is what you were experiencing on the low bands?
Gary
K9RX
hi gary
im trying to figerout how to do it ...its still receiving BC station's........!
If these stations do not disappear when the "WIDE" flag is gone, then look for a corroded connection in the neighbourhood that is mixing these signals. Do you have anything you can direction find?
If they go when "WIDE" is gone (panadaptor within the 80M band) then filtering out the BC band is the option.
Try setting the preamp to no gain0
Thanks guys to all of you... and spichal thanks to 9k2wa ... problem solved...0
I saw 9K2WA spotted you on 75 last night so I figured it was solved - what was it? !
Still mostly using the FTdx5000 here ... it will be a while before I fully transition to the 6700. The antenna project has to get done first.
have a great week Osama.
Gary
K9RX
hi gary
you and 9k2wa solve the problome .... like what you said just zoom in ..... the band in pandapters untel BC stations moved awy..
9k2od, osama
Super! Glad it hear it was relatively simple. Hopefully my antenna project will be done in a month or so - see you on 75!0
- 375 Community Topics
- 106 SmartSDR+
- 427 SmartSDR for Mac
