No DAX TX option in MMTTY sound list
Andrew O'Brien
Member ✭✭✭
Most annoying! When setting up MMTTY for the RTTY contest, the drop-down list of audio devices on the transmit side do NOT include a DAX TX option. I do see that option in the sound device options in FLdigi. So, I suspect that there are too many sound options for MMTTY to handle and DAX TX is not listed. I find it very frustrating that this issue still exists in DAX audio.
I am also just setting up N1MM+ with MMTTY with Flex 6300 and have run into exactly the same problem - no DAX TX in the list.
Anybody any suggestions?
DAX TX is a recording audio so Windows handles it differently.
Make sure you are in the correct input/output group.
You could also make it you DEFAULT recording device in Windows.
Default device might be in the list if the list it limited to the top 5 or 10 devices.0 -
DAX Audio TX is a Playback Device, like your Speakers.
DAX MIC Audio would be the Recording device for the microphone.
In another thread, K6TU posted A link to a program that would hide all of the reserved audio channels making more of the non-reserved audio channels available in MMTTY. This is a Windows problem, about how Windows reports all of the sound devices to programs, not a Dax problem. Some programs are only able to display a limited number of sound devices and only display the first ten of them, for example. Also, make sure that you didn't get bit by the windows 10 update yesterday. Many users have reported this Thursday and Friday. Mine did yesterday, and I need to do some re-installation or repairs to get my cat and sound files back.1
I have a 6500 and had similar problem with MMTTY. I went into the windows audio system and disabled all the DAX items I would never use. Like DAX audio RX 5 6 7 and 8. Do both playback and recording devices. The remaining DAX items will be shown in MMTTY. Don't know what you do if you have a 6700.
Art N4PT0 -
Where did you access the windows audio system to disable them ?0
Go to the speaker icon on the taskbar right click and select playback devices. Select the device and right click and select disable. Use the top recording tab to get to the recording devices again properties to disable.
Art0 -
Thanks disabling the ones not needed helped, would be nice is Flex arranged for them not to be installed in the first place. Also, it seems with some applications like MMTTY the default audio setting randomly switches when MMTTY is booted. So you set the path, everything works, and next time you use MMTTY the path gets switched to something like DAX 4 and takes a minute or two to figure out. To be honest, I have found the constant checking, re-checking of DAX RX and TX in various areas to be really tedious . I have spent more time adjusting these areas today than using the 6300. Giving some serious thought to sending the 6300 back and just keeping the 3000. I still can not get TWO instances of MMTTY working with TWO DAQ receive channels in N1MM+ . I can have DAX 1 with audio in MMTTY or DAX 2 , not both . I was hoping for both in the RTTY contest today.
Andy K3UK0 -
Thanks Salvador. making it the default device cured the problem.
In the past I have disabled all the DAX items that were not necessary but I found that at some stage they would all reappear.
Andy F5VAI
A lot of these problems occur when Windows 10 updates. The last major update wiped out all my DAX drivers and I had to reload SmartSDR. It also wiped out all my MMTTY settings. I had arranged for four instances of MMTTY and now they are all the same so I will have to set it up all over again.
Art N4PT0 -
To bad it is not a Flex problem, then we can fix it...
vous êtes les bienvenus.0
- 335 Community Topics
- 602 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 400 SmartSDR for Mac
- 263 SmartSDR for iOS
- 247 SmartSDR CAT
- 184 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 181 FLEX-8000 Signature Series
- 913 Maestro
- 882 Genius Products
- 319 Tuner Genius XL
- 116 Antenna Genius
- 280 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 736 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 950 Third-Party Software
