SO2R RTTY MMTTY set-up
Andrew O'Brien
Member ✭✭✭
Setting up the basics is no problem, but I have a question about just how folks handle the actual two receiver aspects . Do you really have TWO MMTTY receive windows open (each in different slice) or do you just have one and toggle between them when needed ? You would have to 'share" the one DAX TX option anyway ?
Andy K3UK
Andy K3UK
Usually, it is customary to run multiple instances of the digital mode program. One for each slice.0
Yes you need to install 2 instances of say MMTTY in separate directories. Additionally if you use a second decoder, they will need to be 2 instances, each in separate directories
- 113 SmartSDR+
- 922 Genius Products
- 124 Antenna Genius
