Antenna Genius update
AH0U
AH0U Member
I found by accident there is a newer Windows application for the Antenna Genius and it seems to fix the problem of the app. Window not staying where you put it..... No longer in the middle of the screen... Simple thing but use to drive me nuts
  • W4TE
    W4TE Member ✭✭
    edited September 2016
    Is it on the 4O3A website?
  • Steve K9ZW
    Steve K9ZW Member ✭✭✭
    edited March 2017
    The link to general releases is:  http://www.4o3a.com/index.php/support/downloads/
    Test/Special releases must be handled differently or have another URL.
    The update mentioned is version 3.0.2b
    Steve K9ZW
  • W4TE
    W4TE Member ✭✭
    Thanks, Steve.
  • K1UO Larry
    K1UO Larry Member ✭✭✭
    edited December 2017
    Be aware that the App currently only stays where placed on the  designated "primary" monitor of a multiple monitor system.   If moved to another monitor it will revert back to the primary monitor on the next PC bootup.
  • AH0U
    AH0U Member
    edited June 2019
    I have a multi screen set up and it stays where I put it no matter what screen it is on
  • K1UO Larry
    edited December 2016
    Agreed...  Must have been some hitch here.  I completely reloaded the app and now stays on whatever screen I place it.   All the new features are very nice also.
