Cannot transmit PSK31 with WinWarbler. Receive works fine. RTTY TX/RX works fine.
Tim K8XS
Cannot transmit PSK31 using WinWarbler or MuliPSK on 6700. RTTY sending and receiving works fine. On PSK, I see good level on DAX control Panel TX Stream meter; however, no indication on Radio Panel Level meter. USing Digu as mode. If I change mode to USB, I see good level on Radio level meter and hear good sounds when MON is enabled; however, no power output. Using SmartSDR 1.9.7. Any ideas?
Commander active ?
Andy K3UK0 -
Is the RF power slider set to zero when you go to DIGU? It seems the DAX input is still enabled if you are getting an audio level showing. Does the audio level go up to the red without being red? Is TX selected for the slice you are using?
If you see a good audio level then I wouldn't suspect a WinWarbler setting (you use that for both PSK and RTTY (AFSK)?). Maybe check the configuration for PTT though. I have mine set for Mode Xcvr Ctrl App and Port none.
That's all I can think of. Good luck!
Kevin K4VD
Also check your transmit passband - AFSK tones above the cutoff won't be transmitted.0
- 317 Community Topics
- 575 The Flea Market
- 7.7K Software
- 6.1K SmartSDR for Windows
- 386 SmartSDR for Mac
- 251 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 356 SmartSDR API
- 9K Radios and Accessories
- 122 FLEX-8000 Signature Series
- 891 Maestro
- 50 FlexControl
- 847 Genius Products
- 298 Tuner Genius XL
- 103 Antenna Genius
- 268 Shack Infrastructure
- 189 Networking
- 132 Contesting
- 696 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 921 Third-Party Software
