Better+CW+Options
Michael McGinty
I love CW and my Flex 6300 does it well, actually better than most. I also have several Icoms and FTDX rigs. There several features on these rigs that would handy on the 6000 series for CW.
1. A breaking mode that is not QSK. Some times the noise between dit and dahs is a distraction, especially during rag chews. On the few occasions that I use my linear, it can't follow QSK at high speed. It's an ALS-1300 without the pin diode switching mod. This mode should operate like VOX with easily adjustable delay.
2. Most of my other rigs have two different keying mode for the built in keyer, full duplex and bug mode where only dits are automatic. I like this mode because it allows you to put more character in your fist. In the bug days, I could usual tell who was sending by there fists. Aussies almost always stood out with a distinct accent. Today almost everybody sounds the same, very automatic.
3. My IC-7800 has an auto tune feature on it that works quit well, especially for my tone def contest partner who has trouble zeroing in on most rigs. Hitting the autotune button zerobeats the CW signal in the band pass quit nicely and quickly.
Some of these features may be in the software already, but the are not easily findable or useful in daily use. I switch between keying modes and from QSK and breaking all day. Having it as an out-front control would be useful.
Mike W6MVM
Mike W6MVM
Sorry about some of the bad wording in this post. The Spelling corrector got to me.
Regards, Mike W6MVM0 -
Hi Mike,
Regarding #3 -- CW AutoClick tune
Here is an idea that is near the top at number 4 on the idea list with 39 votes so far. Would this do what you want? You can add your comments and vote to the idea to help get it done.
https://community.flexradio.com/flexradio/topics/ssdr_autozerobeat_on_cw_click_tune
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com
6700 - HW.................. V 1.8.4.84
SSDR / DAX / CAT...... V 1.8.4.168
Win100 -
This is exactly what I'm looking for. I like the click idea rather than a button. Much better user interface and could work better on Maestro.0
Al,
Are these comments in a good place or should I move them and to where?
Mike W6MVM0 -
Mike,
If you add your comments to the "auto click" idea post they will be considered when FRS looks at the idea. Also it moves the idea back up in the list for others to see and comment on or add their votes if they haven't seen the idea before. (sort of a "bump" to the top of the list for a while)
I also use CW skimmer and it doesn't always synch up exactly with SSDR. Often need to tweak the freq to get them synched. I'm hoping the "click tune" would help with that also.
Regards, Al / NN4ZZ
Win10
Delay Slider: Moving Delay slider control the slider control to the right increases the time delay in milliseconds (ms) between the end of a keying element and when the radio transitions from transmit to receive. This effectively controls the QSK characteristics of the radio, where a value of 0ms is full break. Increasing this value will allow different degrees of QSK (semi break), such as listening between letters or words while sending.
Here is the way I would solve your questions: 1. A breaking mode that is not QSK. Some times the noise between dit and dahs is a distraction, especially during rag chews. On the few occasions that I use my linear, it can't follow QSK at high speed. It's an ALS-1300 without the pin diode switching mod. This mode should operate like VOX with easily adjustable delay. Just increase the breakin delay to something that suits you. 3. My IC-7800 has an auto tune feature on it that works quit well, especially for my tone def contest partner who has trouble zeroing in on most rigs. Hitting the autotune button zerobeats the CW signal in the band pass quit nicely and quickly. Just set your CW filter width to 50 Hz and you have a perfect auto tune. Some of these features may be in the software already, but the are not easily findable or useful in daily use. I switch between keying modes and from QSK and breaking all day. Having it as an out-front control would be useful.1
Thanks.
Ken pointed this out on the the AutoZeroBeat conversation. I tried it and it works fine.0 -
I've done this in pileups. Never thought of it as auto tune.
Thanks for your comments.0 -
How about adding an "Autotune" feature?0
Hi Al,
Just wondering. Is there a list of of the top rated "ideas" that have been implemented since the "idea list" has been in existence?
Hi Charles,
That is an interesting question. There are over 1,000 pending ideas and only 56 marked as implemented. (see caveat below) I ran a query of those since the community was started. If you define "top rated" as having at least 20 votes, there are only 4 ideas that are marked as "implemented" for all time. Here they are:
**** CLICK to see full size *****
If you define "top rated" as having at least 10 votes, there are 8 more that are marked as implemented for all time. Here they are:
Caveat -- the idea statuses are not always updated so there could be more. For example some that are marked planned could have been done but not updated. FRS does not seem to consistently update the status on the ideas
FWIW, like many others we are hoping as the big ticket items get done we'll see more of the customer ideas implemented in V2.x, 3.X, etc.
Regards, Al / NN4ZZ
Win10
Good info, Al.
And another caveat....Some of the requests that received a lot of votes have been superceeded by ideas implemented that are actually better than the original idea.
Others are still being considered but are not on the immediate planning, in lieu of more pressing or more difficult improvements.
The neat thing is that there IS an extensive list of proposed ideas and improvements!
Ken - NM9P0 -
This is what I do when using my Amp - the amp has fast vacuum relays but activating the relays for every code element seems a bit harsh so I add 30 ms or so via SmartSDR or Maestro, enough to break between letters but not dots & dashes. This is close enough to full QSK for me and hopefully will help the relays last longer.0
Thanks Al for the nice listing, just was wondering if the "system" was working. You might know an hour after I asked, V 1.9.7 ids released which appears to have one of my most-wanted items (adjustable filters) implemented. If I had just waited one more hour............
I have noticed that when tuning into SSB signals, it's tedious to get onto the exact .000 or .500 frequency, taking several back and forth mouse attempts to do so. While an Auto-Tune feature like ICOM would be nice to have, I would settle for the ability to double click the yellow down arrow control and have it "snap" to the nearest major frequency increment; e.g., default increment might be 200, so a double click would snap up or down accordingly. This would make quickly tuning into a signal before it's gone much faster and easier.
Rick1
- 332 Community Topics
- 599 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 398 SmartSDR for Mac
- 262 SmartSDR for iOS
- 247 SmartSDR CAT
- 181 DAX
- 370 SmartSDR API
- 9.1K Radios and Accessories
- 16 Aurora
- 912 Maestro
- 52 FlexControl
- 873 Genius Products
- 312 Tuner Genius XL
- 115 Antenna Genius
- 278 Shack Infrastructure
- 196 Networking
- 135 Contesting
- 727 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 948 Third-Party Software
