Maestro wont connect via cable
AH0U
My Maestro has decided that it will not connect via the cat5 cable... the wifi in the shack is very poor although the rig is only three feet from the router and everything else connects fine...I have the cable plugged in but the Maestro does not give any option to choose the cable and goes to the wifi which cannot hold the connection and drops out.... sometimes there is a note at the bottom of the screen while booting that says it is connected to both and it first comes on via cable then immediately goes to wifi...any ideas???
You might try... goto Menu>network>Wifi setting.. Select the wifi network and then chose Forget instead of connect.. Then goto radio ( upper right corner) and continue..
AL, K0VM
Poor wifi has nothing to do with being close or far from the router sadly. There is lots of discussion on the forums regarding that.
Mike va3mw0 -
This is the only thing that works for me as well until a new version of the software gives as a bit more control.0
K0VM is correct this is the solution. Forget the wifi connection then you should be able to connect via LAN.
I would love to but I can't get to stop connecting to the wifi.... I have pulled the battery but it still connects to wifi even though the cable is plugged in0
do you have an open network with no password? in any case you need to follow K0VM's instruction to forget the network. make sure you have a link light when you plug maestro in. If no link light you may have a hardware issue with your LAN.
I have traded the connection with other devices and they work fine... There is something amiss with the Maestro as it shows the wifi logo as soon as it is on sonetimes will say connected to both and then flip to wifi as don as the rig is running0
I have converted this topic to a support HelpDesk ticket (http://helpdesk.flexradio.com) for expedited issue resolution. Please respond use the HelpDesk ticket for issue resolution.
If anyone else is experiencing an issue similar to this one, please submit a HelpDesk support ticket for issue resolution.
- 339 Community Topics
- 607 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 172 SmartSDR for Maestro and M models
- 405 SmartSDR for Mac
- 265 SmartSDR for iOS
- 248 SmartSDR CAT
- 186 DAX
- 372 SmartSDR API
- 9.2K Radios and Accessories
- 19 Aurora
- 196 FLEX-8000 Signature Series
- 916 Maestro
- 888 Genius Products
- 321 Tuner Genius XL
- 116 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 137 Contesting
- 745 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 964 Third-Party Software
