Asus NVIDIA GeForce GTX 1060 - DUAL-GTX1060-6G 6 GB GDDR5 Memory /Asrock x58
elan
is Asus VIDIA GeForce GTX 1060 - DUAL-GTX1060-6G 6 GB GDDR5 Memory
will be working okay with my Asrock x58 mother board with the 6700 some issue to open all
slice
or it is over **** ? any help ?
73 elan g0uut
slice
73 elan g0uut
Way overkill, but it will work great. Absolutely no problem running up 8 slices + skimmer, etc., etc.1
I agree. Waaaaaaay overkill. A high-end gaming card is not necessary. And graphics card that has a gig of 128-bit GRAM and supports the latest version of DirectX will be sufficient.0
Well, it all depends guys, there are a few things to keep in mind. The 1060 card is a fantastic deal it offers enough power to run many screens and several resolutions. You could, for example, have a main 4k monitor and additional ones at different resolutions all on the same video card. Another very interesting feature is having HDMI 2.0 which allows you to connect to some of the new 4k televisions and use them as monitors with at 60Hz and chroma 4:4:4.
For SmartSDR in a 24 inch screen, even embedded video cards work. The guys are right, in that case scenario, it is overkill, but it will give you many other features. It is almost like considering the 6700 overkill.
hello Tim
okay thank you but what card will be okay then i use may be old card
is ASUS GTX950-M-2GD5 2 GB GDDR5 Graphics Card is any good
many thanks to all who help
elan g0uut0 -
thank you is ASUS GTX950-M-2GD5 2 GB GDDR5 Graphics Card any good or what is normal one i can use
with the aSROCK X58 ?
That card is a great deal and will run SmartSDR at 4k without an issue. And remember that SmartSDR will go all the way to 4k which is fantastic!0
what one the ASUS GTX950-M-2GD5 2 GB GDDR5 Graphics Card /?
thank you kind
elan g0uut0 -
Yes0
and you haven't really lived until you've run SmartSDR on a 4K monitor -- it's the way to go!0
hello Robert
may i ask you what card you using
thank you kind
73 elan g0uut0 -
Hi Elan
I am running an NVIDIA GTX 780 Ti card with 3GB GDDR5 for almost 2 years now.
It works great with 8 slices on my 4K resolution Asus monitor using the DisplayPort.
73, Bob0 -
Hello Bob
thank you kind for this info
vy 73 elan g0uut0 -
I'm ok with
Gigabyte Z97 Gaming 5 motherboard
Intel I7 4790K
Corsair DOMINATOR Platinum Series 16GB x 2 DDR3 DRAM 2400MHz
Gigabyte AMD R9 380 256 Bit GDDR5 4GB
enough room to do what I need
George, YV5WZ / PY3ZZZ0 -
I use 2 x 29" ultra-wide monitors (2560 x 1080 resolution ) and find it a superb setup.
One display is dedicated to SSDR in fullscreen. I can see detail in the waterfall that almost cannot be heard, and could easily be skipped over otherwise. I often find low level DX that way, i.e. visual clue hunting not just chasing up and down the bands like VFO monkey.
The other monitor has all my logger, rotator, grey line, mapping, SteppIR control, propagation stats on it.
73 de Steve G1XOW0 -
thank you George
vy 73 elan g0uut0 -
hello Steve
i dont know if you use the 6700 but thank you for the info
73 elan g0uut0
- 633 The Flea Market
- 131 SmartSDR+
- 197 DAX
- 42 Aurora
- 955 Maestro
