Out of Band Antenna Tuning
edited June 2020 in New Ideas
Add the ability to manually adjust the internal tuner, a slider for inductance, and a slider for capacitance, to tune for best signal when monitoring outside of the ham bands.
This would be ideal for folks who want to listen to short-wave while not in proximity to, or without, an outboard tuner.
Welcome!
«1
  • Member ✭✭✭
    edited August 2019
    Is that normally found on Ham gear? I have not had a newer radio in some time, just wondering if they offer that now on most radios.
  • Member ✭✭✭
    edited May 2020
    Mister Mystery - how you will tune out of band? How should it work without RF at a SDR? TX out of band ?
    Don't know from what country you are.  A real Ham don't do it :-)
    73 Chris DL5NAM
  • Member
    edited August 2016
    Many newer radios have "general receive" capability that allows for monitoring the multitude of shortwave broadcast bands.
  • Member ✭✭✭
    edited December 2016
    Yes I know about general coverage, what I am asking is,,,do most radios have  inductance, capacitance adjustments for receive?
  • Member
    edited August 2016
    Glad you made the point.
    The purpose is to manually tune using sliders in the software to adjust inductance and capacitance for best receive signal, not low SWR.  Transmitting is not required to tune for best receive signal.  Transmitting is not required to listen outside of the ham bands either, however, being able to match a compromise antenna manually, by adjusting capacitance and inductance in the tuner, can make the all the difference in the listening experience.
    Consider an outboard tuner with manual controls and try it some time...  Several models of LDGs autotuners have manual controls for inductance and capacitance.  Or, if you're a fan of old school tech, you can find plenty alternatives at any swapfest.
  • Member ✭✭
    That’s an interesting suggestion, but I don’t think it would help much, if any, in the HF SWL bands if you have a decent antenna, due to the ambient noise.  While my LDG autotuners have the manual C and L controls but I don’t bother using them, or my manual tuners, for listening for that reason.
    Adjusting L and C manually might help if you use a really, really inefficient antenna (like a mobile whip for the low HF bands), but other than that case I don’t see the benefit.  Even in that case I think you’d be better off getting/building a good Rx antenna.  I use beverages but there are many other types that don’t require nearly that much real estate.   Some folks use small Pixel-type loops with good results.
  • Member
    edited August 2016
    Technically, Yes.  When you tune on the ham bands your receive path will go through the tuner(that's why the band comes alive after tuning) unless you RX on a different antenna. ( in that case you may benefit from manual tuning on the RX antenna)
    Prior to the Signature Series Flex, I've only had one radio with an internal tuner, and it disappointed me that it didn't allow manual control.  LDG does have some models of autotuners that do offer manual adjustment that fills just that purpose.
  • Member ✭✭
    edited August 2016
    Use a high quality external tuner that has continuous inductor, capacitor adjustments like the Palstar and adjust for maximum noise floor.
    Jim, K6QE
  • Member
    edited August 2016
    Well, I'm glad to say that it actually does help in the HF SWL bands on both a windom and long wire.  Sadly, I don't have the real estate for optimal ham band antennas, or SLW band antennas.
    Sounds like you have the means to experiment for yourself! Awesome!
    Hop on a few different bands with a few different antennas that weren't made for each other, manually tune L and C for best signal (try L first and then C), and then switch in and out with bypass for comparison.  Let us know the results.
    73!
  • Member ✭✭✭
    The Flex ATU ( and many others) is basically a low-pass filter fucntion.   SIgnals above the matched band are attenuated significantly.  Signals below the matched freqeuncy have very little attenuation.   In practice, actually matching a received signal may increase the amplitude of the received signal AND NOISE, but will not change the signal to noise ratio.  on receive BYPASS will give you all the signal-to-noise your likely to get.
    AL, K0VM
  • Member
    edited August 2016
    Jim G.
    Yep, nice tuner...  But the real purpose is to avoid an external tuner and use the internal tuner from the software so it isn't necessary to be in proximity to an external tuner.  For example, my computer running Smart SDR is in front of me, my flex and outboard tuner are 40 ft and a flight of stairs away from me (and I'm lazy).  Wait a minute, I cant reach my tuner from my computer, and I cant see my computer when I'm adjusting my outboard tuner. I sure wish I had a way to adjust L&C on the internal tuner, using the SmartSDR softtware, to adjust for best signal(max noise floor) to listen to RNZI outside of the ham bands.
  • Member
    edited August 2016
    AL K0VM,
    But, If manual tuning can get the weak signal on a compromise antenna above the radio's noise floor, you've just accomplished something...
  • Member ✭✭
    edited August 2019
    I might be wrong, but most "auto tuners" use a number of caps and inductors that can be combined in series / parallel combinations using a bank of relays. While this design can simulate an almost infinite combination of inductance and capacitance, it's hardly a "variable" scenario. Since the Flex radios are primarily intended for amateur radio, the development cost and time spent on this feature would not likely do very much to increase the overall sales. The marketing folks might say that "the ROI is very small". Use an outboard tuner - easier and much less expensive. It can be easily connected to the looping connectors. If I had to speculate, this might be something that a user would want if the radio were operated outside the intended amateur bands.
  • Member ✭✭
    edited August 2019
    I'll add some gas to the fire,most peeps that are using SDR receive only radios aren't using tuners that I know of. I have a PlaySDR that I just hook up to any of my antennas. But now you have me thinking, when I tune my TS-820S I preselect for the greatest noise with the drive control, so when I get chance I'm going to hookup my external tuner AT-200 to my SDRPlay and see what happens.
  • Member
    edited August 2016
    You are correct, most auto tuners use a finite combination of inductors and capacitors to perform their function.  The idea is to be able to adjust, with slider controls in the software, both capacitance and inductance within the limits of the tuner.   And in the context of the idea, it is for listening outside of the regular ham bands otherwise we could automatically tune.  Given that the 6500and 6700 already have tuners integrated, and that it is an option for the 6300, the development cost is limited to software and firmware, which is an on-going process.  Thus low investment for a feature that might actually be used by folks that enjoy SWL.  Flex has already seen fit to support General Receive in their SDRs. Q.E.D.  The real development question here is whether or not there is a way to address the tuner's L & C switching capabilities from the software interface.   Another question: how many features are in the signature series radios that you never use but were incorporated anyway.  I doubt, I'll ever operate two radio single operator in a contest even though a configuration profile exists. However, I have already been enjoying listening outside of the amateur bands.
    Cheers!
  • Member
    edited August 2016
    Rory,
    I'd love to hear your results...
  • Member ✭✭
    edited August 2016
    At the risk of having this turn into an ongoing debate, I'll make this my last post. Considering the cost of a Flex 6000 radio, I doubt very many SWL'ers are going to purchase one just to listen.  As an SWL'er of more than 50 years an external tuner is much more versatile, and definitely less expensive. As a ham, such a feature would not in any way entice me to buy the radio (for amateur purposes). As a person who works in the consumer electronics industry, I have an extensive amount of knowledge and respect for allocating development resources to any product. You allocate them where you get the biggest return on the investment (time and money). From that point it becomes an issue for the marketing guys to decide. QED
  • Member
    edited August 2016
    WA2SQQ,
    You may be right, perhaps SWL'ers may not purchase a flex just to listen, then again, there aren't a lot of  hams that would buy one either even though it's one of the best quality receivers on the market.  The idea of the feature is for those who do pony up the $$$.  I do wonder what Flex marketing was thinking when they told Flex engineers that they had to have a receive only 6700-R for $1100 less than the 6700.  Maybe they do know something we don't...
    Having worked in hardware and software development since the late '80s, I've come to learn, in a creative work environment that isn't too topheavy, sometimes a feature gets implemented just because a young engineer or two thought it was a cool idea, saw how to get it done, and he, she or they had nothing better to do for a few hours after work.  I do hope Flex is that type of organization, and that Flex management appreciates employees that are willing to spend extra hours innovating, even if it's not in the production plan.  In my experience, some of the best ideas implemented came from throwing aside the roadmap for a few hours and asking one self, "Let's see if we can do this."
    So, you  are correct, marketing may not see value in a feature.  After all, why do you need 8 slice receivers, you've only got one set of ears?  For me, if it can't happen on the 6700, maybe I can trade the 6700 in for a 7700 and get that feature a few years from now.
    Hope to see you on some of the other threads.
    Cheers,
    Mystery Ham
  • Member ✭✭
    edited March 2018
    Regarding reasons to purchase. One of my reasons to purchase the 6500 was because it would also let me use it to do utility and shortwave broadcast listening. Many years ago I purchased a Drake TR-7 for the same reason. The whole world of HF doesn't revolve around Ham Radio.  As for Mystery Ham there are a couple things you can do.
    1: Purchase an all band antenna like Comet 250B for RX use, or
    2: use a small manual antenna match or per-selector and run it into RX-A.  just watch the pan-adapter for the area of interest to peak.  Check MFJ I wouldn't expect Flex to add the manual adjustment to the ATU.
  • Member ✭✭
    edited August 2016
    In case you missed it, there are now a pair of 6700-R radios on the ISS. I believe that most of us here on the community are unaware, or forget, that amateur radio isn't the only, or maybe even the most lucrative, business that Flex is engaged in, given the opacity of government contracting. When I first got the full dog & pony show at a ham convention, I immediately recognized that I'd have gladly killed someone to get Flex capability when I was working for folks who shall go unnamed, long ago, in a galaxy far away.
  • Member
    edited August 2019
    Dan,
    I appreciate your sentiments regarding the HF world not revolving around Ham Radio...  Seems to be an American point of view as most other countries offer shortwave programming along with the ubiquitous possession of shortwave receivers among the citizenry.
    From my point of view, part of the beauty of operating a signature series flex is the ability to operate away from the hardware and thus, away from a manual antenna match or pre-selector. Thus the feature request for software based L & C controls when listening out of the Ham Bands.   Call me lazy...
    the comet 250b is interesting but the 15 to 30db hit compared to a tuned dipole or vertical seems a little steep.
    Anyway, on the flex tuner, if it is possible to read and write bytes that turn on and off relays to switch in and out inductors and capacitors so the flex hardware automatically memorizes it's prior tune and goes back to it when I change away to another band, tune, and then return, then just maybe the software can manually operate those relays with 2 sliders with values from 0 to 255.  If it's just feeding the tuning processor a frequency and the tuning processor pulls the value from dedicated memory that is inaccessible to anything else, then all bets are off. ( however, I'd bet the Flex folks are keen on diagnostic data and that the registers controlling the tuning relays can be read and manipulated)
    Cheers!
    Mystery Ham
  • Member ✭✭
    edited August 2019
    Here is a little empirical data on the matter of the role of the tuner regarding received signals.  It was suggested that the tuner will make the signals stronger but it will not improve the signal to noise ratio (SNR).  I performed the following test with my FLEX-6700 using a 160 meter dipole antenna.
    1.  I tuned to an inactive portion of the 31 meter band and observed the band noise as -97.1 dBm.
    2.  I tuned to a nearby AM broadcast station (6.089,700 MHz) and observed the signal amplitude at -70.1 dBm.
    I then switched the antenna output of the FLEX-6700 to a Palstar DL2K dummy load and transmitted with a power of 10 Watts while invoking the internal tuner in the FLEX-6700.*  At this point the FLEX-6700 had performed a "successful" tune at that frequency.
    3.  I again measured the inactive portion of the 31 meter band and observed that after "tuning" the band noise was -82.4 dBm.  The noise floor had risen by approximately 8.8 dB.
    4.  I tuned to the same nearby AM broadcast station (6.089,700 MHz) and observed the signal amplitude at -61.3 dBm.  The signal strength of the subject broadcast station had increased by 21.1 dB.
    Now we do the SNR calculations and we find that they are essentially identical.  It would appear that using a tuner makes the noise floor and the subject signal stronger but the SNR remains about the same.
    Reg
    * As a MARS member I have an unlocked FLEX-6700 so I can transmit on 6.089,700.  I did not transmit on the air using an antenna.  I transmitted into the above specified dummy load.  Given that I didn't transmit into the receive antenna the match wasn't perfect but it was certainly on frequency.
  • Member
    edited August 2016
    Paul,
    I had never considered the following quote from slide 24...
    "The optimum source impedance for components is not always the same as required for maximum gain, and so there will be an “optimum input mismatch” –In such cases, although the operational available output signal is reduced, the available output noise is reduced proportionally more"
    It provides some interesting insight regarding building a receiver, and, If I understand it correctly, a slight mismatch, presumably in the right direction, may help to differentiate signal from noise, though I also understand it to be noise within the receiving hardware itself not the background noise on the band.
    But it does bring up a point that I think I have failed to make and of which many people appear to be unaware: Tuning (matching) for receiving will only help if there is a signal near the noise floor of the receiver, not near the background noise.
    Thanks for your thoughts and observations
    Cheers,
    Mystery Ham
  • Member
    edited August 2016
    Reg,
    I appreciate your initiative in actually doing some experimenting!
    I have some suggestions that may improve the testing methodology and, perhaps, provide some intriguing results.
    I’m going to use a term, receive system, that represents the combination of your radio, coax, antenna any other connected device in the signal chain to hopefully avoid confusion.
    Consider the following:
    If there is a signal that is 5db above the combination of background and local noise on the band, yet, that signal on a mismatched antenna is lost below the noise floor of the receive system, matching that antenna to your receive system may bring that signal up above the noise floor of the receive system.  Empirically, on occasion due to quiet band conditions, this has been my experience when operating outdoors away from noise sources.  Yes, I could switch in a preamp in this case, but I would be adding in the noise figure of the preamp into the mix and potentially reduce the signal to noise ratio.
    Many have accurately observed that matching an antenna increased the background noise equally with the signal and the signal to noise ratio stayed the same.  The only fault in the test was that the background noise was already above the noise floor of the receive system.
    Fortunately, there is a way to simulate quiet band conditions when you don’t have them.  (I repeat… this is only a simulation…)   Requires an attenuator: MFJ makes one with SO-239 adapters that works from 1db to 81db in 1db steps, however you don't want to transmit with it in line.
    Start with an antenna that requires matching in a band near a very strong signal. 40m may be ideal for this test because Americans can transmit in the regions otherwise reserved for shortwave broadcasters.  Verify the tuner is in bypass (also verify the preamp is off).  Then add attenuators until the noise floor stops dropping (the receiver's noise floor has been found) then add another 10db to 15db of attenuation.  Take a measurement of the strong signal compared to the noise floor.  Manually tune without transmitting for best signal (or remove attenuators, tune and replace them.)  Now measure again...  What did the signal do compared to the noise?
    Some may ask “why not use a preamp then?"  A preamp could be used, and the preamp's noise figure would be added to the receiver's noise figure.  The signal path through the tuner is passive and thus much less noise is added.
    Not everyone has quiet band conditions where they live for working weak signals near the noise floor of their receive system. So, the concept of matching an antenna to improve reception, or using a preamp for that matter, may not apply in their experience and unfortunately may be met with skepticism.
    Given the aforementioned skepticism, the concept of allowing manual adjustments of L & C in the tuner remotely from SmartSDR, may seem just as insane as the concept of adding preamp hardware to a flex radio and having the ability to turn it on and off remotely from SmartSDR.  ;-)
    Cheers,
    Mystery Ham
  • Member ✭✭
    Hi MH,
    I just heard Joel Hallas give a good talk at the end of his podcast "The Doctor is In" This episode they talked about SDR's and at the Q/A section someone asked about antennas.
  • Member
    edited August 2016
    Thanks for the info...  A internet search a few hours ago took me to the ARRL site, but the podcast hadn't yet been posted.  I'll check later.
  • Member ✭✭
    edited June 2020
    Per Part 97 you are not allowed any RF outside the Amateur Radio bands. Manufacturers are disallowed from providing a means to do this.
  • Member
    edited August 2016
    Kevin K4VD,
    Your question about how Flex might handle an antenna match for the 6700-R has me thinking...  It may not be so far fetched if components are modular. The existing board from the 6700 could then be used. However, since transmit power isn't involved, lower cost components that can cover a broader range of mismatches could be used instead...
    It appears that the 6000 series already remembers it's prior match settings when switching between bands and locations within a band and puts them into play without transmitting when those frequencies are revisited.  So, once a manual match has been set from the software, things should be in good order as long as the antenna ecosystem doesn't change.
    One step farther:
    I've never heard of an antenna analyzer requiring a call sign to be input so it can ID itself while it's attached to an antenna. Nor have I seen an analyzer limited to the edges of the ham bands. Perhaps there is some room within the law in various countries to use a momentary low power signal to provide analysis and automatically match an antenna system on an otherwise receive only device.
    This may shed some light... http://transition.fcc.gov/ftp/Bureaus/Engineering_Technology/Documents/bulletins/oet63/oet63rev.pdf
    Mystery Ham
  • Member
    edited August 2016
    Bob and Paul,
    That is correct, no transmitting required.  Only manual adjustments of L & C via SmartSDR software.
    And I believe only one country has a Part 97 rule (law?)   ;-)   Though, I'm confident many countries have something similar but with a different set of requirements.
    Though, let me pose a question...  Does that mean an analyzer cannot legally be used in America because it doesn't automatically turn off when you reach the band edges while it's connected to devices or components such as antennas that are designed for frequencies covered by Part 97?
    Mystery Ham
  • Member
    edited August 2016
    Bob, There is a whole world beyond the North American border where the FCC has no remit.
