smartsdr ios problems with VPN and audio
Do you have a VPN portal setup in your home If not, search Softether on this community. Lots of detailed threads on how to set it up Then setup a L2TP VPN on your iPad. Again search VPN and iPad. Lots of detailed threads1
Thanks Howard, I think that I have the VPN portal set up in my home, I followed Chris' instructions for the Raspberry Pi so I will search as you have suggested. I guess I didn't know what to search on.
John
W9KXQ0 -
Glad to know that works. I was going to go that route at first but a couple reasons I didn't. I've read that open vpn had not been upgraded or continually supported in some time, so as many on here have done, I went with soft ether. Not sure if that is a viable option at the router level or not. I know most that support vpn do so with open vpn.. The other reason is that my R8000 is set up as an access point which disables the ability to set up vpn on the advanced menu. Is there a way around that? If I set up vpn in the normal Wi-Fi router mode first, then switch to AP mode, will it keep the vpn running?0
- 389 Community Topics
- 659 The Flea Market
- 53 Aurora
- 971 Maestro
- 945 Genius Products
- 307 Shack Infrastructure
- 813 Peripherals & Station Integration
