connecting flex to steppir
I don't know if other people are doing it differently, but I control my SteppIR with Dtutil running on a side-kick computer. I use a USB to RS232 cable from the computer to the input of the control box for the Stepper.
Jim, K6QE
Thanks for that. but can you go a little more basic? What is a side-kick computer? I tried the LP step link it read the frequency from HRD but did not pass it to the Steppir controller. Di d you plug into the back of the 6300 usb port or where did you pick up the information?0
You connect everything (Amp, Rotor, SteppIR) through the computer controlling the Flex and NOT the Flex Directly
You can then control all your CAT devices (Amp, Rotor, SteppIR) via DDUTIL which acts as a traffic cop to sort out all your control information...
I would definitely NOT use HRD to control anything as it adds huge useless overhead. HRD Logbook is OK and their Rotor Control is OK but they all interface through DDUTIL
Time to start reading the fine manuals...
http://k5fr.com/DDUtilV3wiki/index.php?title=Main_Page
ok i have a serial on the computer connected on com 9. On the dd utility I set the first rcp to the upper right to com port 9. It did accept that. I don't see anything else to do on that page. On the features page I see it has found the radio. I have checked band data/macro by radio. It still doesn't work. What did I leave out? I tried both a regular and null modem cable. Neither worked. I set the steppir controller to kenwood and went through all the speeds but still no connection.0
Hi Larry,
you will need the cable from the data out on the steppir controller to the computer connected to usb too serial cable
Hope it helps
Larry KE2YC
Larry. There are 100's of posts here on how to do it Here is one you should read https://community.flexradio.com/flexradio/topics/steppir-transceiver-interface-with-6500-ddutil-mandatory0
I read though all those. What I must be doing wrong is either setting the ddutility wrong or the steppir control. My com port shows up in the device manager and seems to be set correctly. But still i get no interface with the transceiver interface. I have the steppir controller set to kenwood and used different speeds and still nothing.0
Here is my setup 0 -
Are you using a null modem cable /0
I have it set up like yours shown above but on com 9 which is what I am using. I am not using the rotor so I dont have that checked. The panel on DDUtility shows information about the radio. But the antenna does not change. I checked again to see if it worked with my yaseu and it does so the box is okay. When I click on home a notice comes at the bottom of the screen saying that the elements are retracting but they dont if i click on calibrate a similar message comes up saying that they are calibrating when i click on restart there is no message and nothing happens. I have used both a null modem cable and a regular cable. Is there something I am missing. Thanks so much for your help with this.0
Is COM9 a physical port ? The SreppIR needs a physical port0
No this computer does not have a serial port output. it is a usb to serial adapter. It is the same adapter that does work with the FT 9000d and the steppir and works fine there. Is it different with the flex. I deliberately used the same adapter and com port that is working with the 9000 so I could eliminate the problem. The 9000 uses the Y cable from steppir for the 9000 that runs to the radio, to the steppir and to the computer. The 9000 also requires HRD to make it all work. Possibly that is the problem that the flex needs that actual serial port which would mean a new machine
Usb to serial port diecrtly to Steppir via null modem cable.should work. Not sure I understand the rest of your wiring diagram0
that is what i have now. I have the usb to serial adapter plugged directly to a null modem cable and then to the back of the steppir. Is there something I have to do to the DDUtility to turn it on?0
I should set the steppir box to 19200 19200 and kenwood right?0
also when i change frequencies on the flex i get a pop up at the bottom of the screen that says CAT Server send Error It appears the server is not connected please correct the error and try again I looked it up and in DDUtil it sadys to open the sscat test tab I don't find such a tab.0
Correct0
- 379 Community Topics
- 631 The Flea Market
- 120 SmartSDR+
- 193 DAX
- 38 Aurora
- 947 Maestro
- 924 Genius Products
