Need the latest SmartSDR and Power Genius Software?
SmartSDR v3.1.12 and the SmartSDR v3.1.12 Release Notes. | SmartSDR v2.6.2 and the SmartSDR v2.6.2 Release Notes.
SmartSDR v1.12.1 and the SmartSDR v1.12.1 Release Notes. | Power Genius XL Firmware v3.4.16. | Power Genius XL Utility v2.2.10.
connecting flex to steppir
I notice that a number of people have their Steppir antenna connected to their Flex 6xxx. I have a flex 6300 and a four element steppir. Can someone just provide a step by step process to make the connection. I use HRD software and have it set to control My VL 1000 amp and ft 9000d which works fine. But I cannot figure out how to make the steppir work with the flex (or the vl 1000 for that matter) Any help would be greatly appreciated. I do have a serial to usb adapter and a null modem cable.
- 70 Community Topics
- 1.9K New Ideas
- 120 The Flea Market
- 5.4K Software
- 4.9K SmartSDR for Windows
- 35 SmartSDR for Maestro and M models
- 87 SmartSDR for Mac
- 144 SmartSDR for iOS
- 150 SmartSDR CAT
- 69 DAX
- 279 SmartSDR API
- 7.1K Radios and Accessories
- 5.8K FLEX-6000 Signature Series
- 557 Maestro
- 14 FlexControl
- 723 FLEX Series (Legacy) Radios
- 153 Power Genius Products
- 119 Power Genius XL Amplifier
- 12 Power Genius Utility
- 22 Tuner Genius
- 41 Shack Infrastructure
- 22 Networking
- 89 Remote Operation (SmartLink)
- 50 Contesting
- 128 Peripherals & Station Integration
- 62 Amateur Radio Interests
- 405 Third-Party Software
I don't know if other people are doing it differently, but I control my SteppIR with Dtutil running on a side-kick computer. I use a USB to RS232 cable from the computer to the input of the control box for the Stepper.
Jim, K6QE
You connect everything (Amp, Rotor, SteppIR) through the computer controlling the Flex and NOT the Flex Directly
You can then control all your CAT devices (Amp, Rotor, SteppIR) via DDUTIL which acts as a traffic cop to sort out all your control information...
I would definitely NOT use HRD to control anything as it adds huge useless overhead. HRD Logbook is OK and their Rotor Control is OK but they all interface through DDUTIL
Time to start reading the fine manuals...
http://k5fr.com/DDUtilV3wiki/index.php?title=Main_Page
you will need the cable from the data out on the steppir controller to the computer connected to usb too serial cable
Hope it helps
Larry KE2YC
