SmartSDR for iOS Add Ona
Joe, i assume name must be specified in this case, like basic profile for SSDR iOS, othervise it will not be executable, but in anyway we need to have detailed instruction in this case0
It is working now (http://manuals.roskosch.de/smartsdr-ios/)0
Sergey, can you please try now? It's probably now available in Russia.
Regarding the Profiles:
You can select one in the list and then you need to use on of the top menu items "Use" (which will switch to the profile), "Save" which will save the current settings to the selected profile or "Copy..." to copy selected profile to another name.
Instead of "Use", you can also double-tap on a profile name.
vy 73,
Marcus, DL8MRE
I've decided to delete my comment, to avoid hijacking this thread into another linux vs ??? quagmire. I'll try to rewrite it into something a little less volatile.
SDRgadgets73, Jay - NO5J
Hi Marcus, tried , nothing changed - > Server Time Outin any way also tested Profiles - make no sense, Use or double click- no reaction with my iPhone, however in case double click on profile iOS_default _profile reaction immediate
hmmm, no way from my home QTH:
Suggest that you ask whomever decides such things at your ISP to unblock the manual site0
Howard, i have tested today 4 ISP's , but packets lost after redirection via hetzner.de0
BTW, Off Topic: have repaired today my 2K-FA -> broken PSU with 48V: RSP-3000-48, PSU a bit modified by Experts, but result for now positive - i am on air again !1
Possible that Hetzner.de has blacklisted the site..
Had that happen to some of my sites a few times... it takes time and effort to convince them to remove a site from the blacklist
May be this is a issue, will test tomorrow with my IT in Berlin, lets's see.
I can agree with that Jon... I suspect all this candy will be available when PPV begins (Pay Per Version)0
Hi Howard,
thanks for your compliments but just one correction.
Everything, really everything has been developed completely by myself. I had to focus on speed and latency so I can't use that small piece of Code provided as public by Stu (which is even only the communications library consisting of e few lines of code). I think that piece of code was also just meant as example and for learning purposes. Normally such things are coded in a different way. I was also using Swift and not the older Objective-C development language that Stu was using.
But you are absolutely right with one point: Many Beta Testers! I am still thankful to all Beta Testers who provided great feedback about bugs, suggestions and positive as well as constructive negative feedback that all definitely helped me to provide the App as it is. You Howard have been one of the (very active) Testers so - as mentioned on one of my mails - this App is not just my baby, it is also yours and the Baby of many others who have helped. Thanks again!
And, of course, I hope we don't stop here as I have many ideas for next versions.0 -
Where is the tuning wheel??..I turned it on in the IOS Settings but cant see anything show up that indicates a tuning wheel.
You must activate it in the settings screen.0
LOL...Hi Ken.. you read my question way too fast!! Its on but don't see any type of tuning wheel I recognize. Also I have a ton of profiles to select from but cant seem to get them to actually load into the IPad.
Sorry, I DID read right past you saying it is ON! I was in a hurry to get home and try it out after work. My VPN and rig powered off at home due to a power outage glitch, and the rig wouldn't power up! Somehow the "Remote On Enabled" had gotten switched off and I couldn't remotely power it up. All is well now.
If you haven't found out yet, if you tap the slice flag, it appears. You can drag it where you want it. When you single tap elsewhere on the screen it closes. When you tap the slice flag again, it appears.
Hope this helps...0 -
Aha... got it now. thanks Ken. Now to figure out how to use my profiles to switch quickly between Bands and Modes. I do not see any explanation in the manual.0
I'd gladly pay a few hundred for an OSX version of SmartSDR..
And my Wife got me a Samsung Tablet at Christmas, so I wait for some joy.......0 -
I am going to close this praise post due to the number of technical questions being asked and answered. It is a "best practice" to start a new topic for questions and problems rather than co-opting an existing post whose title has no reference to the issue being discussed.2
- 384 Community Topics
- 649 The Flea Market
- 149 SmartSDR+
- 262 SmartSDR CAT
- 961 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
- 142 Amateur Radio Interests
