shielded cat5 cable/tool
hi
is any one can give some info
i am looking for shielded cat5 cable that can be recommend by other
as well the crimp tool it need i see a lot of them but what is the best to go with  ?
as well some info tectonic  to crimp it with the right layout will be great
thank you kind
73 elan g0uut
Welcome!
  • Member
    edited August 2016
    My experience: I have never had any success with shielded Cat5, none, and the special connectors are a royal pain. I always found I was really chasing another problem, grounding, usually, that was solved without shielded Cat5.
  • Member
    edited February 2018
    hello Frank
    so you use normal CAT-5 ?
  • Member
    edited August 2016
    Normal CAT-5 ? No, I used Belden shielded CAT-5. Oh, maybe this is a matter of semantics:  Perhaps you are refering to regular CAT-5 as shielded CAT-5 ?  My mistake, sorry.
  • Member
    yes this what i mean the  Belden shielded CAT-5. i think is very good  not sure i can get it in UK
    73 MANY THANKS
    elan g0uut
  • Member ✭✭
    edited July 2017
    I have used the Ubiguiti "Toughcable" shielded cat 5 cable very successfully.  You can get it with or without a wire for hanging it in the air.   I just use ordinary tools to install the connectors (use the connectors from Ubiguiti).   Here is a YouTube video that shows you how to put on the connectors:   https://www.youtube.com/watch?v=85ZXHT8U_Zg    The only time I had problems it was definitely "pilot error."    John AD6NR
  • Member
    hello John
    very kind thank you , but what cable it use on the  you tube is this the name of the cable
    Toughcable" shielded cat 5 cable ? thank you again very interesting what ssdr you use it with
    6700?
    73 elan g0uut
  • Member
    edited August 2016
    Thanks for the reply, John. Considering the expense, I wonder what situation would dictate using the shielded cable ? Perhasp a code requirement at your end ?
  • Member ✭✭
    edited September 2016
    I bought that cable because I am going to put a Ubiquity microwave system up at a ham radio site. One end at my house about 15 miles away and the other on the mountain.  The cable run at the site is not long (~20) but I did not want to have it fail as the site is not accessible during the winter and gets lots of nasty weather. The shielded cable is good when there is (minor) static charging and the ToughCable really is tough!  I also had to make two runs underground from the router in my house to the transmitter outside my workshop (~260' each run).   I bought 1000' of the cable for $130 and 100 of the proper connectors for $46.  Not all that expensive really.   John
  • Member ✭✭
    edited July 2017
    I used the Ubiquity "ToughCable Pro" .   I did not need the extra wire (carrier) as all my runs where short or underground.   Here is the link   https://www.ubnt.com/accessories/toughcable/
  • Member ✭✭✭
    edited April 2020
    Why you not use CAT 6 or CAT 7 if worry about RF problems? And there many different types of cables in each CAT group exist. Most CAT 7 cables have a metal covered plugs. Try Google and/or Wiki to see the details. Most good cables are double or triple shielded.
  • Member ✭✭
    edited July 2017
    Chris - I am not worried about RF problems with the CAT 5e cable.   The CAT 7 multi-shielded cable is almost 3 times as expensive as the CAT5e here in the US.
  • Member
    well Chris you are right
    http://shop.sommercable.com/en/Cables/Bulk-Cables-Fiber-LAN-CAT/Cat-7-SC-Mercator-CAT-7-PUR-581-0071...
    https://www.dienadel.de/supra-cables-cat-7-patch-hrhf-netzwerkkabel/a-353629039/
    i like to the sommer cable they are the best of the best cable out there as well for audio staff
    g0uut/dl9fcc
