shielded cat5 cable/tool
elan
hi
is any one can give some info
i am looking for shielded cat5 cable that can be recommend by other
as well the crimp tool it need i see a lot of them but what is the best to go with ?
as well some info tectonic to crimp it with the right layout will be great
thank you kind
73 elan g0uut
thank you kind
73 elan g0uut
My experience: I have never had any success with shielded Cat5, none, and the special connectors are a royal pain. I always found I was really chasing another problem, grounding, usually, that was solved without shielded Cat5.1
hello Frank
so you use normal CAT-5 ?0 -
Normal CAT-5 ? No, I used Belden shielded CAT-5. Oh, maybe this is a matter of semantics: Perhaps you are refering to regular CAT-5 as shielded CAT-5 ? My mistake, sorry.
yes this what i mean the Belden shielded CAT-5. i think is very good not sure i can get it in UK
73 MANY THANKS
elan g0uut0 -
I have used the Ubiguiti "Toughcable" shielded cat 5 cable very successfully. You can get it with or without a wire for hanging it in the air. I just use ordinary tools to install the connectors (use the connectors from Ubiguiti). Here is a YouTube video that shows you how to put on the connectors: https://www.youtube.com/watch?v=85ZXHT8U_Zg The only time I had problems it was definitely "pilot error." John AD6NR0
hello John
very kind thank you , but what cable it use on the you tube is this the name of the cable
Toughcable" shielded cat 5 cable ? thank you again very interesting what ssdr you use it with
6700?
73 elan g0uut0 -
Thanks for the reply, John. Considering the expense, I wonder what situation would dictate using the shielded cable ? Perhasp a code requirement at your end ?0
I bought that cable because I am going to put a Ubiquity microwave system up at a ham radio site. One end at my house about 15 miles away and the other on the mountain. The cable run at the site is not long (~20) but I did not want to have it fail as the site is not accessible during the winter and gets lots of nasty weather. The shielded cable is good when there is (minor) static charging and the ToughCable really is tough! I also had to make two runs underground from the router in my house to the transmitter outside my workshop (~260' each run). I bought 1000' of the cable for $130 and 100 of the proper connectors for $46. Not all that expensive really. John0
I used the Ubiquity "ToughCable Pro" . I did not need the extra wire (carrier) as all my runs where short or underground. Here is the link https://www.ubnt.com/accessories/toughcable/
Why you not use CAT 6 or CAT 7 if worry about RF problems? And there many different types of cables in each CAT group exist. Most CAT 7 cables have a metal covered plugs. Try Google and/or Wiki to see the details. Most good cables are double or triple shielded.1
Chris - I am not worried about RF problems with the CAT 5e cable. The CAT 7 multi-shielded cable is almost 3 times as expensive as the CAT5e here in the US.
well Chris you are right
http://shop.sommercable.com/en/Cables/Bulk-Cables-Fiber-LAN-CAT/Cat-7-SC-Mercator-CAT-7-PUR-581-0071...
https://www.dienadel.de/supra-cables-cat-7-patch-hrhf-netzwerkkabel/a-353629039/
i like to the sommer cable they are the best of the best cable out there as well for audio staff
g0uut/dl9fcc0
- 324 Community Topics
- 589 The Flea Market
- 7.8K Software
- 6.2K SmartSDR for Windows
- 393 SmartSDR for Mac
- 259 SmartSDR for iOS
- 246 SmartSDR CAT
- 177 DAX
- 368 SmartSDR API
- 9K Radios and Accessories
- 14 Aurora
- 149 FLEX-8000 Signature Series
- 905 Maestro
- 50 FlexControl
- 863 Genius Products
- 305 Tuner Genius XL
- 114 Antenna Genius
- 273 Shack Infrastructure
- 193 Networking
- 135 Contesting
- 714 Peripherals & Station Integration
- 134 Amateur Radio Interests
- 936 Third-Party Software
