smartsdr ios microphone difficulty
2»
  • Ken - NM9P
    Ken - NM9P Member ✭✭✭
    edited December 2016
    What is your processor setting and PROC meter reading? Are you getting full power output or close?
    Have you powered your rig down and back up recently?
    I have had a rare couple of times that I needed to do a power cycle to sort things out, especially after changing back and forth between clients rapidly, or experiencing a network dropout at the wrong time. Btw: the Mon function is not implemented yet, as far as I know. Nor is XVTR selection, DEXP, or FDX.
  • Steve K9ZW
    Steve K9ZW Member ✭✭✭
    edited June 2020
    What I get for not reading the manual. Wasn't intuitive that PTT in the upper bar isn't actually PTT with the actual PTT being a toggled by what first impression was just an indicator. Laughing at myself on this, but perhaps it could be a bit clearer that the "real PTT" is toggled to show/not-show by the PTT that is on the gray bar? Of course I could read the manual or watch a video, but I wanted to see if I could muddle through unaided. 73 Steve K9ZW
  • KY6LA_Howard
    KY6LA_Howard Member ✭✭✭
    edited August 2016
    FWIW.. none of the iOS products should require u to RTFM.
  • Ken - NM9P
    Steve, I was confounded by that the first time I began testing it a few months ago, until I noticed the PTT button toggling on and off as I pressed the PTT on the menu bar! It was one of those "Oh, Duh!" Experiences. Ha ha.
