Oh those down home OpusStream blues ...
Gary L. Robinson
Problems with trying to figure out how to properly get AND use an OpusStream to enable remote operation in my client program. I am using the FlexLib (not ethernet) API.
Do I need to create an OpusStream? Just what all needs to be done to accomplish operating remote like SSDR by just using the remote button?
My App connects locally (with my PC and the 6300 both going into the same gigabyte switch) and no problems. But from my laptop using wireless on local LAN I can connect but no laptop audio.
Of course, SSDR on the laptop connects fine also and when I click on the Remote button I get audio just fine.
Anybody have any luck doing this in FlexLib ??
---Gary WB8ROL
---Gary WB8ROL
2
It's curious. In version 1.8.4 of FlexLib I see this in RequestOpusStreamFromRadio() // send the command to the radio to create the object...need to change this..
//_radio.SendReplyCommand(new ReplyHandler(UpdateStreamID), "stream create opus");
It's curious. In version 1.8.4 of FlexLib I see this in RequestOpusStreamFromRadio():
Gary,
If your application works fine on one system and not another, I would suspect a firewall issue. Could you disable the firewall temporarily to test this theory?
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
