SmartSDR for iOS App is AMAZING!!
I have an iPad 2, 4 years old and with the latest IOS slower than snails and won't run this app, at least not very well. I recently received my Maestro and so far love it but the iPad Pro 12" is calling out to me for SmartSDR as well as Netflix etc...
So, I just ordered a new iPad Pro 12", got a good deal on one so I'll be buying this app as soon as the iPad arrives.
Any one had any luck trying to use this program with Softether L2TP configuration for WAN operation?
Interested in Jim's question. I would like to use the APP from a remote location.
Jim, Doug,
There are VPN related comments in this thread:
https://community.flexradio.com/flexradio/topics/smartsdr-ios-problems-with-vpn-and-audio
The short answer is yes, Softether L2TP VPN works fine with SmartSDR for iOS.0 -
I have been at work today using softether with my iphone 6s. Four hours so far with zero disconnects.0
I've been listening to 40m all morning here at work! Running Softether L2TP VPN with SmartSDR for IOS through my 4G connection. Using a iPad Mini Air 4 with built in mic. I just worked a special event W8W and he gave me a glowing audio report. He said he couldn't tell I was working remote! I have not gotten any disconnects or dropouts. It's been running steady all morning. I'm pretty impressed so far!
Cal/N3CAL
Many thanks for all your hard work Marcus. John AF3K has summed it all up, quite amazing. Runs superbly on my iPad Air with 6300.
Andy F5VAI
Works great on WAN0
I can't get softether working for the life of me.0
UDP ports (500, 4500 and 1701) need to be forwarded to the SoftEther Server device IP
It runs very well on the 12" iPad Pro - SmartSDR for iOS is very smooth on that hardware.1
I'd love to get it, but I can't find it on Apple's APP STORE in the USA, either searching "smartsdr" or two words, "smart sdr" Where do I get it?
The above it is the response from the App Store
Go to the iTunes store not the app store.
Jon...kf2e0 -
Question: Is Raspberry Pi still required when connecting SSDR-ios with SoftEther VPN?
What would be most helpful, is an updated video showing the complete steps required just for getting SSDR-ios up and running with SoftEther and an iPad and/or iPhone.
A Raspberry Pi ws never required. What is required is a server for Softether. That can be run on many platforms. Your Windows machine that you use for SmartSDR is an obvious choice.
Jon...kf2e0 -
Also works very well with OSX Server's VPN. On the beach in Los Angeles listening to my rig!2
What's confusing is that many suggestions in the Flex Community refer to the 2-part K6OZY video for setting up SmartEther with SSDR-ios. More confusing, the first 22 minutes of Part 1 discuss provisioning a Raspberry Pi, when the applicable material starts thereafter.
Again, it would be helpful for a power-user to start with a clean slate and either explicitly state the step-by-step instructions or produce a new video.
Paul, W9AC
There are lots of videos on how on the Internet to set up a VPN on the iPhone/iPad
Here is one
http://www.howtogeek.com/215730/how-to-connect-to-a-vpn-from-your-iphone-or-ipad/
It is so incredibly simple...
Connect to PPTP, L2TP/IPSec, and Cisco IPSec1.To set up a VPN, open the Settings app on your iPhone or iPad,
2. tap the General category, and
3. tap VPN near the bottom of the list.
4. Tap “Add VPN Configuration” to add your first VPN settings to the phone or tablet. If you need to configure multiple VPNs, you can add them from this screen, too.
5. Select the L2TP option for L2TP/IPSec, PPTP for PPTP, or IPSec for Cisco IPsec
If you are using SoftEther at your base then choose L2TP
6. Enter your VPN’s connection details on this screen to connect. .
That it...
Here is how to connect a softether VPN to the iPhone
Again.. incredibly easy to do..
Howard,
Way past that part and had that set up long ago...I'm referring to the Ethersoft set-up for use with the iPhone's L2TP. After getting past the 22 minute intro, one problem with the K6OZY video is that the screen image cannot be expanded for a clearer view.
Paul, W9AC
Adding to Howard, I had to open Port 51 for Softether VPN (L2TP) to allow my iOS devices to connect. Go figure....0
Have you run it over VPN yet?0
I have on an iPad Pro 9.7" - PPTP VPN over fiber, cable broadband, and LTE/4G hotspot. Also directly on my iPhone 6 with PPTP VPN over LTE. I've had no issues (other than when cell service is spotty/drops out while driving). The cable broadband experience was particularly good considering it was in a very rural area with 20/2 mbps service. Needless to say, it works excellent on your LAN at home as well.3
@ Paul
Did you get it working yet?
@Paul, to put it another way....The Pi isn't required on the home network.
But if you want to use L2TP/iPsec VPN with Softether to host your iPad/iPhone, you must have the Softether server running on SOMETHING in the shack/home network.
It can run on your main shack computer, a separate older computer doing server duty, a compatible "hacked" router, a NAS Drive Box (I call mine a "Toaster.") or a simple Raspberry Pi, in order to relieve your other computers of this duty.
I purchased a Raspberry Pi 3 at Dayton this year with intentions of experimentation with Softether in the shack, but haven't gotten around to it yet -- testing SSDR-ios has been too much fun and I already have it going with a simple PPTP VPN connection.
The other usage of the Raspberry Pi that others are confusing with this is when interfacing the Maestro via VPN. Since the Maestro does not yet have VPN Client software integrated, some folks, like K6OZY have been using a Raspberry Pi as a wifi connection / VPN Client to allow the Maestro to connect to your home VPN. Since the Softether Client can be installed on the Pi, it made easy sense.
Hope this helps.
I am amazed at the creativity some in our ranks have demonstrated. I need to learn to program my own Pi in order to keep up!0 -
Howard & Ken,
Yes. Got it going yesterday and described what it took to get there!
Paul
Oops! I even read your post yesterday! (They say that short term memory is the first to go.....)
But I had a brain cramp and was only focusing on the Raspberry Pi Question!
Perhaps my answer will help clarify things for someone else.
Glad you got it running. Having fun now!
Ken - NM9P0 -
Awesome APP! Much fun from my iPhone 6+ and iPad. Not certain the XYL is exactly thrilled that I can work QSOs from a phone pulled from my pocket. Thinking she is worried I will "go radio" if houseguests drone on mindlessly. Sounds better to me though! Excellent "smile making" application- thank you! 73 Steve K9ZW1
- 311 Community Topics
- 566 The Flea Market
- 7.7K Software
- 6.1K SmartSDR for Windows
- 385 SmartSDR for Mac
- 253 SmartSDR for iOS
- 241 SmartSDR CAT
- 176 DAX
- 364 SmartSDR API
- 9K Radios and Accessories
- 112 FLEX-8000 Signature Series
- 887 Maestro
- 50 FlexControl
- 842 Genius Products
- 434 Power Genius XL Amplifier
- 296 Tuner Genius XL
- 112 Antenna Genius
- 267 Shack Infrastructure
- 188 Networking
- 428 Remote Operation (SmartLink)
- 132 Contesting
- 687 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 916 Third-Party Software
