smartsdr ios problems with VPN and audio
Also, The demo audio is atrocious. Is it supposed to be that way? It is all choppy and distorted on both devices. as if it is experiencing packet loss. but this shouldnt be if it is simulated as a demo.
Why is this program any better than a VNC and Skype which are both free?
Not to be a buzz **** but I've been trying this since yesterday and wasting a lot of time trying to get this working when I already have a method that works just fine.
Thoughts? Suggestions?
I'm sorry you're having problems with L2TP on your IOS device, but you won't get any help from Flex on that. VPN is unsupported by Flex. They currently will only support a LAN configuration.
This app is much MUCH better because it's the full client at your fingertips rather than redirection of another computer.
If you can't get your VPN connected, and you have no need for it on your LAN, you should likely pass for now until 2.0 comes out.0 -
Howard
If you will be using a iPad or IPhone remotely via the built-in iOS L2TP client you will need to setup additional port forwarding rules on your router. Those forwarded ports are:
UDP 1701, UDP 500 and UDP 4500
I had the same issue because I forgot to do the port forwarding. Once I setup port forwarding everything started working fine!
Cal/N3CAL0 -
All those ports are open already... Sigh....0
I connect to the computer running the flex software directly and its like being home. I've been doing this for 4 years now using a VNC program and Skype without a hitch. I thought maybe this would be a better way to go. Looked interesting.0
I'm pretty sure that is the most that you can do with the demo but I have been very happy with the app so far since purchasing it. There are a couple of minor issues but audio quality (even over 4g) is very good.1
I note in the manual the program calls for an iPad "3". Has anyone tried the program on a iPad Air ( not 2) or do I have to use this as an excuse to upgrade ?1
Howard, what are you using on the radio end of your network to provide a L2TP VPN connection? There are many who have had excellent luck with SoftEther.net. I myself have used a PPTP VPN included onmy ASUS router with my iOS devices. It isn't as secure as L2TP, but works. I have also used OpenVPN on my ASUS router to VPN with my Windows laptop from the office.0
If someone is showcasing an app that costs 50 dollars, wouldn't you think they would make sure that the audio quality (for demo purposes) would be good? Something isn't making sense.1
Ipad 3 came BEFORE the Air. Should work OK]] But you really wanted to see it on the iPad Pro0
iPad Air and iPad Pro here, plus iPhone 6. All work very well, with good audio (much better than the demo quality). The Pro is noticeably smoother, Sam you might imagine. Bandwidth is selectable - and it helps a great deal on slower connections. Haven't tried via VPN yet, but am not too worried about that.0
Ken,
I am trying to setup the PPTP VPN on an ASUS router and IPad. Did you have to do any port forwarding on the router for the SmartSDR IOS to work, and where did you get the L2TP Secure Key that is required as part of the configuration on the IPad?
Reggie
iPad Mini Air 4 here. Works good with VPN over 4G. (Radio Side has Softether running on a Windows 10 Machine)
Cal/N3CAL0 -
Ken, Ive been using soft ether for years but with windows on both ends. Never had an issue.0
Howard, the IOS app is designed to work on a Local Area Network such as your home. It does a great job, and I have had a lot of enjoyment under this type of use. When I'm in the living room, bedroom, or kitchen, I can connect to my flex and it is an amazing experience. Well worth the $50. I've had some success using it over the WAN using both SoftEther and OSX Server VPN (Both L2TP). Ive yet to get the waterfall to work when doing this. It doesn't matter if I'm usin a Maestro, SmartSDR for Windows or IOS, the waterfall just doesn't play through my VPN configuration. Everything else works like a champ including the Panadapter. That the waterfall doesn't work for me is not Flex Radio's or Marcus. We are trying to trick the software to be used in an environment for which it was not designed. This will be native in upcoming releases of SmartSDR for Windows and IOS. Until then I still search for the "special sauce" that gives me the full native experience via VPN connection. If anyone has any ideas, I'm all ears. As to the audio quality, th demo is of a prerecorded QSO which has been saved within the applet. High quality audio takes a lot of memory., artificially bloating the size of the App. The demo is to give you a taste of the experience. There is nothing nefarious going on. It was a smart decision on Marcus's part to tchoose a smaller applet size at the cost of lower quality audio recording on the demo.0
I would think its either a required port not forwarded or a firewall rule needs to be set for the waterfall data to pass through. When I get stumped with something like this the first thing I do is temporarily set the router to pass everything through (DMZ). If that still don't work temporarily turn any software/antivirus off. This will at least rule those out.0
best guess is that you have a port set wrong or a firewall issue
Or perhaps u do not have L2TP protocol enabled in SoftEther.
The iPad/VPN should easily connect to the VPN via L2TP
Bottom Line
It's only $50 + Spots and Bandmap = $59.99Try it.. if you do not like it
How to get a refund using iTunes
http://www.imore.com/how-to-get-refund-itunes-app-store
I suspect that you will like it enough to want to keep it..
I am running it on an IPAD 3 and it runs pretty good on wifi once you turn the bandwidth down, the audio smooth's right out. My 3G cellular/vpn connection is choppy.0
I ran the Alpha versions over 4G Cellular from France in June via VPN to La Jolla, CA and I got superb audio reports .
I have run the production version over 4G Cellular from my iPhone in my car again with good reports..
However - to qualify this... my Internet is 300Mb/s/30Mb/s in La Jolla...
YMMV
Well I paid ($69.95 up here) and the app will not connect to the Flex. When I try to connect I gat "Searching error" in the pop up box. Tried scanning and connecting directly to the fixed IP address of the Flex. Still no luck. I can connect just fine using the K6TU Remote app (and with the Maestro) so it does not seem to be a network issue.
Tim VE6SH
Yes it is a better way because it's a native app for the iPad/iPhone. But then I do not have a Windows tablet0
Think of it as a video demonstration
It is not A cool which are working version of the program. For a working version program you need to buy the app and connected to a flex 6000 series radio0 -
You set ur own Secret Key in SoftEther and in the iPhone client Use something simple like VPN0
Tim
Can you ping the flex ip from ur iPad? Are you on the same ip subnet0 -
It is NOT intended to showcase SSDR. It is only a simple video to show how the app looks. More dynamically than screen shots. The demo audio likely will be rerecorded sometime in the future but realistically it's irrelevant to the actual operation of the app. Why don't you see if you can find someone wth a 6000 near you that you can actually see a real radio in action.0
Howard, opened is one thing. Did you forward them through the firewall to your SmartEther server?
I just tested it and it worked wonderfully.
These are my ports on my Router running DDWRT. The first column is a name (anything works). The 2nd is the Port From, 3rd is the Protocol, 4th is the target IP address inside your network (where Softether is running) and the forth matches the 2nd.
Mike va3mw
Yes, I guess. But this is a 1 person show, not Microsoft with any entire media team. I would cut him some slack.
Mike va3mw
Tim, I can Teamviewer into your network if you like and help out. Make sure on your Wifi router that you have client security turned off. There are a few tuning tools that prevent 1 client from seeing another client. This may be your issue.
Wifi vendors do this to limit the amount of traffic being sent out on the Wifi network. Not all traffic is echo'd from the hardwire network to the Wifi network.
Mike va3mw
If not on the same subnet, such as when using iOS VPN or other situations, it is necessary to enter the current IP of the Flex6k radio, and turn on "Fixed IP" and turn on the "Scan instead of discovery" options on the Settings menu. This works great for me, both via WiFi at home and while away from home using iOS VPN.
You sound like ur in the UK. If so, there are dealers that can demo the 6000. Or post ur area location. U might be surprised to find someone nearby0
- 378 Community Topics
- 116 SmartSDR+
- 923 Genius Products
