SmartSDR CAT will not open
Bill Speedie
New Flex 6500 installation with version 1.8.3 of SmartSDR and SmartSDR CAT on a Win 10 PC. Maybe I did something out of order because SmartSDR runs OK but SmartSDR CAT refuses to open, either by clicking the icon or from the list of apps. The task manager does not show the CAT program running. Do I need to uninstall the CAT program (and VSP program?) and reinstall from the CD? Tried "run as administrator" and that didn't work.
Thanks for any advice. -- Bill, KA6T
So many people have had the dreaded lost cat syndrome. It appears one has to completely uninstall SmartSDR and reinstall. Completely uninstalling is a proverbial pain in the ****.
Jim, k6QE
Also, 1.8.3 was withdrawn. You probably want to download 1.8.4.0
Bill,
After updating to win 10 version 1607(?), I found that after re-installing SSDR I had
to run the SSDR installation one more time without uninstalling SSDR to get CAT on board.
It took running the SSDR installation program -twice- before the whole installation succeeded.
My system may be quirky. I've been in the windows 10 "insiders" program from the
beginning, and some upgrades, especially the earliest ones, required extra effort to get
things right. Many later versions went smoothly, not needing any particular attention.
This was the first time that I had to run it twice to get VSP/CAT to install. The first time
through SSDR was installed. The second time added CAT. Good luck with this. Windows
10 still has some "mysteries" associated with it, but you will get it going. The 6500 will do
a fine job for you and it will be great fun. Hang in there, and as Bob suggested, get 1.8.4.
Ned, K1NJ
I have converted this topic to a support HelpDesk ticket (http://helpdesk.flexradio.com) for expedited issue resolution. If anyone else is experiencing an issue similar to this one, please submit a HelpDesk support ticket for issue resolution.
- 246 Community Topics
- 489 The Flea Market
- 7.1K Software
- 331 SmartSDR for Mac
- 243 SmartSDR for iOS
- 222 SmartSDR CAT
- 163 DAX
- 348 SmartSDR API
- 8.6K Radios and Accessories
- 766 Maestro
- 41 FlexControl
- 733 Genius Products
- 255 Tuner Genius XL
- 85 Antenna Genius
- 229 Shack Infrastructure
- 153 Networking
- 120 Contesting
- 115 Amateur Radio Interests
- 813 Third-Party Software
