Here we go again...
KF4HR
This happened awhile back, then for no apparent reason the problem disappeared. Now it's back. For months SSDR works fine, then today I fire things up. Screen pops up normally and I have tuning and audio, just no spectrum or waterfall display. A bit of troubleshooting and I find that if I turn my anti-virus s/w off, the display and waterfall reappear and SSDR runs normally, although running without A/V SW bugs me, so I decide to write an exception in the A/V SW for the Flex software. This normally works with other programs, but not this time. Anyone have this issue with SSDR and Vipre Anti-Virus SW?
This is almost certainly the internal VIPRE firewall causing this, there is a document on their website that describes how to diagnose and fix this problem: https://support.vipreantivirus.com/support/solutions/articles/1000122894-firewall-blocks-or-prevents...
Waterfall data is transmitted on a different IP protocol (UDP) than the radio control data (TCP). I agree 100% with Kevin and Phil that a change to your PC's firewall or Internet security suite is the reason for this behavior.0
I have the same problem using Vipre, and the solution is as stated above. Add a rule to the Vipre firewall allowing the program to ALWAYS access the firewall.
NOTE: every time you update, you'll have to add a new exception as the firewall recognizes each individual version of CAT/DAX/SSDR as separate and unique programs (which they are).0
- 112 SmartSDR+
- 944 Maestro
