Will the flex 6500 support 2 meters?
So, you've got an idea for next release; make Nyquist zones accessible to (interested) users.
And you get one more feature, for free.
73, Maximo
Yes Ken I picked up the 144, 222 and 432 boards from transverters-store.com and was a breeze to get them setup on my 6500. See my QRZ page under myTransverters section for lots more details. Works like a charm for SSB ragchew virtually no drifting. I'm sure there is a little but not noticeable over several hours. I keep the output at about 5 or 6 watts max but play around milliwatts from time to time. Drives my 2m amp with no issues. Only problem is that the 6500 is just on 2m. Should mention FM simplex and repeaters works as should, takes some setup of the various parameters be sure to save the repeater in memory. I also used the 432 and 222 versions with similar results.
Great QRZ page Mike! I have bookmarked it!
David G4NRT0 -
Thanks for the informative video Mike. I believe I'll give this transverter a try.
73 Jim
WU7G0 -
I have tried a few different transverters on my 6500 (including the Ukranian ones) and the difference between those and my shiny new Kuhne TR144 PRO is like night and day. I am very impressed, it is the first Kuhne that I have owned but I suspect it won't be the last.
Phil, Can you share some more details about how Khune + 6500 works?
How you feel the difference?
73, Maximo
Maximo,
Of course, Phil can answer for himself but I also have two Kuhne Transverters (the 432H and the new TR144 PRO) so thought that I would dive in!
In a comparison test with my previous (and also very good) HA1YA transverter, I can hear more and with less noise. I get excellent reports on my signal and audio when working through repeaters and also (with the appropriate waveform) with D-Star.
You only need to look at the Kuhne website and see the numbers! The frequency stability is amazing and I am able to copy satellites with ease on both 2m and 70cm.
I have all my transverters configured for two cable operation with a 28Mhz IF. I attach them to my 6500 using a Kuhne (again!) transverter switch.
They are pricy, you cannot deny that, but they are about the best that I can find here in Europe!
David G4NRT0 -
Yes of course, I find it much quieter on receive than either the Ukranian or my SSB LT2S. Being able to lock to my 10Mhz ref means that frequency is rock solid. It also allows me to configure for every type of operating mode (including separate or single TX/RX connections for both antenna and IF). The biggest benefit for me though is I have problems with every other transverter being overloaded by a nearby ham who regularly operates 400w into 4 stacked yagis but so far the Kuhne has performed very well.
73 Phil0 -
David, Phil, thanks for your comments.
It seems clear the Khune's device superiority.
73, Maximo - M0HAO
- 352 Community Topics
- 615 The Flea Market
- 8K Software
- 3 SmartSDR+
- 6.3K SmartSDR for Windows
- 412 SmartSDR for Mac
- 267 SmartSDR for iOS
- 250 SmartSDR CAT
- 187 DAX
- 375 SmartSDR API
- 9.2K Radios and Accessories
- 22 Aurora
- 212 FLEX-8000 Signature Series
- 922 Maestro
- 894 Genius Products
- 323 Tuner Genius XL
- 116 Antenna Genius
- 284 Shack Infrastructure
- 200 Networking
- 138 Contesting
- 974 Third-Party Software
