Maestro audio disappears
James Madden
Initially the maestro audio is ok but sometimes it goes away. Why is that and is there a way to adjust the audio volume on the maestro? Thanks jim
Ps if i go back to sdr the audio is fine.0
Jim,
Which audio output(s) on the Maestro are you having problems with ? Internal spkr, external spkr, headset ?? Or are you having a problem the TX audio ?? I have not had any problem with my Maestro audio disappearing..
AL, K0VM
Jim, did you get this resolved? I was having audio coming out of my Maestro B headset when I pulled out the mini plug to try and listen over the Maestro speakers — I didn’t hear anything, but when I plugged my NRad W1 headset back in I no longer could get any audio that way either. I’m not muted. I checked my antenna receiver - that’s ok too. I have rebooted Maestro but I’m likely missing something obvious. I’ll check with you all here first before I submit a ticket for support. Thanks everyone.0
- 383 Community Topics
- 640 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 262 SmartSDR CAT
- 201 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 305 Shack Infrastructure
- 214 Networking
- 142 Amateur Radio Interests
