6 meter repeater offset incorrect
James Madden
i have another post regarding 2m repeaters not working. i decided to bypass the 2m setup using the DEMI transverter and go directly to 6 meters,
I setup a frequency of 53.29 mhz with an offset of -1.7 mhz. i could hear people talking in the repeater but when i transmitted the frequency shown on my panadapter was more like 53.246.
however when i keyed my mike i did see the repeater respond with a signal at 53.29mhz.
could this be part of my problem getting a 2m repeater to respond. please see attached graphic.
That's probably just a small spur showing up - widen your panadapter to cover both frequencies in the pair for a better view. 1.7 MHz is an unusual 6m split, by the way.1
I can easily hit some local 2m repeaters w/ 0.6 offset and a 6m repeater w/ a 0.5 offset. Not certain why you are having difficulties. It does appear you learned how to enable CTCSS.0
James, are you sure the offset is 1.7Mhz? 6m repeaters usually have an offset of -500khz. 1.7Mhz is the offset for 70cm repeaters in the UK.
edit: Obviously the 70cm offset in the UK is 1.6Mhz.... Not enough caffeine this morning!0 -
Heres the specs on the repeater. If im calculating correctly the offset is 1.7 Mhz Output Input Tone Call Sign Location 53.2900 51.5900 100.0 W7AW West Seattle [WS ARC]0
Ill double check and post.0
Just looked it up and all 6m repeaters in seattle area have a -1.7 mhz offset.0
Did you try it with the standard -500khz for the heck of it. Maybe the printing of the offset is wrong0
Yes you are quite correct, sorry I had never seen that offset used for 6m repeaters before!
Totally correct. When i expanded the pan adapter to show the repeater input frequency and keyed the mic the frequency was correct. Still no audio response from the repeater though.0
Maybe wrong pl tone or you are just not hitting the repeater0
Also your display shows you at 53.290.100 and not 53.290.00
James, what do you mean by "no audio response"?0
In my part of the US, more 6 meter repeaters at on a 1 MHz split than any other. There are a few that have more than 1 MHz offset. Other regions have apparently adopted different standard splits on 6 Meters.0
When you stretch your panadapter to show the transmit frequency, can you detect any audio on the display as you talk?
I think at this point I would set up simplex with tone to TX on 51.590 while watching panadapter on 53.290. You can then play with tone and frequency (offset) until the repeater responds. If it never happens, hardware configuration, mode is suspect or you are just not hitting the repeater. Your display TX is off frequency but tone and FM mode are enabled. When I look up the W7AW repeater, your repeater setup looks perfect except for the exact 53.290 frequency. I suggest you lock the frequency when you are playing with it to prevent accidentally touching the mouse wheel and changing it.1
Im used to the repeater teansmitting when i key my mic. Its not doing so. Jim0
I double checked. The offset is -1.7 mhz. Jim0
Thanks very much Dave. Ihave sent my yaesu walkie talkie in for repair as even though i have it on simplex with no offset, my flex 6700 panadapter is showing it transmitting the wrong frequency.jim0
Using the latest version of SmartSDR for Windows (1.8.3), I have verified that on FM, both a + and - offset of 1.7 MHz works properly on FM. The 6m FM repeaters in my area use a -1.0 MHz offset. Some require a CTCSS tone, others do not. I have hit both types of repeaters and opened them.
Even had a short QSO on one, so I do not believe there is anything systematically broken in SmartSDR that requires fixing. I think your issue is local to your setup, such as incorrect repeater info, antenna issues of possibly a configuration problem1 -
I agree Tim - when I was in Bellevue, (just east of seattle) I was able to key up and talk to people using the 6 meter repeater on 53.170 repeater with minus 1.7 MHz split and 100 Tx tone.
Now thats the only repeater I could key up, so my range was not good (in temp apartment) but it worked. The configuration was straight forward and did not seem tricky. I do not remember the display - just configured the radio, and keyed it up. Chatted with two people and then went back to HF, and then back on a plane and gone.
Anyway Cheers and good luck !
thanks Tim.0
- 390 Community Topics
- 661 The Flea Market
- 54 Aurora
- 971 Maestro
- 945 Genius Products
- 308 Shack Infrastructure
- 216 Networking
