Smart SDR V1.8.30 will not update radio permanently, every time I restart it needs update
Sounds to me like you are not updating the version you think you are.2
Strongly suspect there is a bug in the operator ;-)
Try removing 1.7.30 AND 1.8.30 from your system first, then reboot the computer.
Now reinstall 1.8.30 and upgrade the radio as required.
Stu K6TU
That may do it. May open a support ticket. I know they are swamped with Maestro 1.8.3 update that was released that had bug. Fortunately I didn't do that update and freeze my Maestro. But Dudley did indicate to my friend that had the same issue as me, to just run 1.7.30 on Flex radio for now as they sort this out.0
Be sure to read the following before uninstalling:
Remember that updating SSDR does not remove the old version or the Start Menu shortcut for it. If you click on the shortcut without first replacing it, you are loading the previous version and will start a "downgrade."1
Oh I always delete the old shortcut. This is not the problem. I am running the correct version shortcut. After updating the radio all shows correct version. After I shutdown and then later restart with the correct shortcut it still shows old version and that radio needs update. This happens each time.0
Problem solved. It's Maestro. Every time I update to new 1.8.3 Smart SDR on the 6500, when I turn on Maestro, the only way it will run is to run the V 1.7.30 update on Maestro which takes the 6500 backwards. UGH. The 1.8.30 file to download on Maestro won't download as it has serious bugs in it. So why won't Flex send all Maestro owners an email to tell them of this problem?
So now I have to run the 6500 on version 1.7.30 if I want to use Maestro.
Flex has made many statements about this issue to all customers.
https://community.flexradio.com/flexradio/topics/issue-with-maestro-v1-8-update0 -
Yeah, but what they didn't say is if you want to use your Maestro don't bother upgrading your Flex radio to 1.8.30. instead leave it at v1.7.30. That would have saved me a lot of headache.0
They did say that0
What they said was not to download the Maestro 1.8.3 software for the Maestro. They did not say to not download the 1.8.30 software for the Flex radio.
Here read it
https://community.flexradio.com/flexradio/topics/issue-with-maestro-v1-8-update:
You are not the first one to run into this issue. It occurs with every update since the beginning of SSDR. One issue is that SSDR does not automatically delete the older versions of software like most software does.. So people are constantly clicking on the wrong legacy icon and forcing downgrades and upgrades...
While It would appear to be rather obvious to any who has paid attention to this community for the past several years that ALL devices which includes the Radio, Maestro and Computer [SSDR] must be on the same software version to operate correctly.
But I guess that Flex needs to add the following statement to the Manual and perhaps as a header to the community...
But Heck.. Hams never read the manual either or
for that matter most don't bother to search the forums either
So I guess some of us Elmer's will continue to answer the same "it will not update" question over and over and over again until someone actually reads a manual or learns how to use the search function or just plain deletes the earlier software versions when they upgrade...
- 634 The Flea Market
- 132 SmartSDR+
- 198 DAX
- 42 Aurora
- 267 FLEX-8000 Signature Series
- 956 Maestro
